You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Went to drive away this am and listen to 132 (sirius) and in pressing the SR button on my factory NAV unit is immediately says "Connection Error - Contact Dealer"
Does anyone have any ideas?I thought maybe a fuse had gone for the sirius module but I can't find what fuse # is uses... the NAV unit acts as if the module isn't there (no info showing up under Sysinfo).
not trying to be smart A but have you payed the sirius bill lately?
just making sure the basic troubleshooting is out of the way
__________________ Eric
2000 Ford F-250 Crewcab Shortbed 4X4 5.4, 4.10 gears
stock height (for NOW), T3 grille guard with hella lights, cherrybomb extreme muffler, cb and satellite radios, many minor mods with more be putting on everyday.
yup it is a lifetime subscription and I did check with sirius and there's no problem at their end. Also, when I go into sysinfo it should show the # of the sirius module, but it's blank.
the only other option i can think of before ripping into the radio or fuses is to have sirius send a re-activation signal to your radio (shouldn't cost anything).
if that doesn't work then i would look at fuses (doubt that is the problem), and then from there on out it could be a connection problem with the antenna setup. last if none of those then there could be an equipment problem.
