installed a set of injectors and now now start harness for injectors burned on glow plug side, is it ok to disconnect glow plug relay to run for now until i can get another harness. thanks in advance
thanks, got it going but it has a lope at idle now, don't know if it is just the bigger injectors, or if there is air in the system yet, it seems to take a little more cranking to start now to.
Ditto drive it and then clean out the FPR screen after some miles. Seriously clean the screen I can't explain it but I cleaned the scree when I did my II's then had to redo it afterwards. Trust me. Rubberduck helped me with this.
