Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-28-2008, 07:29 AM
E30tdf is starting off with a positive reputation.
460 2 Piece Rear Main Seal
1986 460 F250 4x4 T19 Trans
I have had to replace my rear main seal about every 18 months for the last 10 years. It holds back the oil for a while and then the leak is back. I am very careful about getting the seal in carefully and off set the seal mating services about 3/8 inch and RTV sealant where the bearing cap mates.
Do any of you have the same issue? What can be done to stop the oil leaking in these buggers?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-28-2008, 07:58 AM
Karl Keicher's Avatar
Karl Keicher is starting off with a positive reputation.
I had a 390 that was the same way- the only way I was able to cure it was to remove the engine, flip it over, and remove the crank for the seal install. Its alot of work and sounds like a "no way" idea but working wick seals around the crank just doesnt seem to hold. So, I would say, nature of the beast?
__________________
It's all good!
I wont be wronged, I wont be insulted, and I wont be laid a hand on-I dont do these things to other people and I require the same from them! jw
'04 F-250 Super Duty PSD
'03 Cadillac DeVille 32valve northstar
'79 F-150 Recently acquired project
'03 Kenworth T-600
  #3 (permalink)
Old 06-28-2008, 02:57 PM
Piffery1 is gaining momentum as a positive member of FTE.
Sounds like you might have a groove worn in the crankshaft where the seal rides. Ended up replacing the crank on an old Chevy that had that problem.
  #4 (permalink)
Old 06-28-2008, 04:47 PM
jason85351's Avatar
jason85351 is starting off with a positive reputation.
go to the auto parts store and get yourself som Bars Leaks Rear Main Seal Treatment. That stuff has always sealed my rear main up. i use it every oil change
__________________
1985 Ford F150 351w 4x4 lift 35" BFG Mud Terrains
Finally Finished driving the truck again till november then putting her in storage
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
