06-28-2008, 03:49 AM
Front tank is the main tank, rear tanbk is the auxilery.
The switch is located on the heater control panel on the right hand side.
The sending units on this model of truck is notorious for going bad. When you lower the tanks you can check the fuel gauge by grounding out the wires (connect both sending unit wires together for a breif moment) and seeing if the gauge raises beyond a quarter of a tank. If it does the sending units or the floats are bad.
Good luck, and welcome to the forum.
