Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-27-2008, 08:20 PM
boggerted is starting off with a positive reputation.
New truck wont crank
Im buying a 1989 F-superduty with a 7.3 IDI that right now wont crank. I know the engine isnt siezed, but when you turn the key to start, the fender mounted solenoid clicks and the coolant temp gaauge rises, but no crank. What should I look for? Also, where is the GP solenoid? thanks
__________________
2000 Ford Excursion-6.8L V10 gas guzzler
1984 Ford F250- my project- 351w with t18 4 speed w/ granny, gauge set
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-27-2008, 09:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Glow plug solenoid on an 89 is usually on the rear of the intake manifold.
Do you here a second click from low on the passenger side of the motor?
There is a second solenoid mounted on the starter.
No crank issues are usually a dead battery, bad connections or a dead starter.
You need two good batteries, at least 850 CCA each.
All electrical connections need to be clean and tight.
Excessive cranking (more than 20 seconds without a cool down period of two minutes) is what usually kills the starter.
Also inspect the battery cables going in and out of the passenger side battery terminal on the positive post.
If the insulation is brittle and discolored, you may have internal corrosion and a bad connection in that clamp.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #3 (permalink)
Old 06-27-2008, 10:20 PM
I only hear one click, but why are ther two solenoids for the starter? The connections all seem tight and clean. Ill check the batteries tomorrow.
__________________
  #4 (permalink)
Old 06-27-2008, 10:54 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
Also, The solonoid on the fender can click but not make contact. I change bad ones all the time at work that click but don't make connection. I would turn the key on and make sure the truck is in netural or park with park brake set and jump the 2 larger bolts on the solonoid with a pair of plyiers, screw driver or something else and see what happens. Also, tapping on the starter some helps in some situations.
And like posted above by dave, definatly check all the electrical connections from the battery to the starter and that your batteries are fully charged.
And the reason for 2 solonoids is because the starter solonid uses more current than the ignition switch and wires in the dash to handle. So to bypass that problem, they put a frame mounted relay (or solonoid if you want to call it) on the fender that can handle the extra current without make the wiring a coupple guages bigger.. Also, since it does require alot of current just to kick in the solonoid on the starter, you would have a large voltage drop across all the wiring through the dash so by putting in the relay cuts down on the distance from the battery to the starter solonoid. And a relay is much easier to replace than an ignition switch.
And for terms, I think ford and international call the solonoid on the fender a relay (since thats is all it is) and the starter has a solonoid. Good luck
__________________
LOADED LIKE A FRIGHT TRAIN, FLYING LIKE A JET PLANE.
1993 Ford Mega cab long bed dually diesel 7.3 IDI w/Banks sidewinder Kit, e40d w/4:10s
1995 chevy K1500 4x4 350 4l60e
1990 suzuki sidekick 4x4
  #5 (permalink)
Old 06-28-2008, 01:01 AM
Dodge/Cummins is starting off with a positive reputation.
Tapping the starter sometimes works and it's worth a try to get it going, but if it does your brushes are shot, REPLACE IT NOW!
My truck did the same thing about 3-weeks ago. It had bad brushes as well as excess cranking that fried the brush holder done by the former owner repedely "cranking" the air out the fuel system to get it started.
  #6 (permalink)
Old 06-28-2008, 08:31 PM
Well, I did some more work on i today, and it seems that the relay is functioning, as when you turn the key to start, 12v is present on both sides of the relay. However, the starter mounted solenoid doesnt click or do anything. I tried to jump that solenoid, but couldnt fit a screwdriver in there to make a good enough contact, only sparks. Can I inspect the solenoid to see if its bad?
__________________
  #7 (permalink)
Old 06-29-2008, 01:22 AM
If you "jump" the studs and all you get is sparks the solenoid on the starter is either shot or the drive (some times called a bendix although that's a brand name of a drive) is stuck in the ring gear teeth.
It's not that hard to pull the starter and check it with jumper cables.
Put it in a vice, put power to it, put a load on the drive with a wood hammer handle or something (if it spins) to see if it has any torque left to it. You should not be able to stop the drive. BE CAREFULL doing this! Don't grind your fingers off in the nose housing.
If the starter spins but doesn't kick out the drive it's your solenoid. If the drive kicks out but doesn't spin it's your starter motor, probably just the brushes.
  #8 (permalink)
Old 06-29-2008, 07:21 AM
Okay, ill pull the starter. How many bolts hold it to the bell housing? I dont want to miss one and damage the bell housing. Also, if the solenoid on the starter is faulty, can you replace just the solenoid?
__________________
  #9 (permalink)
Old 06-29-2008, 08:02 AM
mejonz's Avatar
mejonz is starting off with a positive reputation.
should be three two are pretty easy one kinda tough universal and extention and patients it'll come out
__________________
Registered as 85 F-250. Farm truck from East Texas C-6 auto 6.9 ltr stock dana 70HD dooley 4.10 limited slip powr lok.IT just runs and runs new belts old tires. Its a 85 f-350 with 85 f-250 cab does that make it an f-300?
  #10 (permalink)
Old 06-29-2008, 08:33 AM
PLC7.3 is starting off with a positive reputation.
Disconnect batteries before doing any starter removal....... live wires.
Do and inspection of the pax fender wiring...... there is a large plug with orange and black wires it can melt.
__________________
93 F250 SC 4x4 E4OD 355LS
  #11 (permalink)
Old 06-29-2008, 01:23 PM
You definitely can replace just the solenoid. If you have a good/honest rebuilder around there you might pull the tail cap off and look at the brushes and if they are worn down and replace them or have them replaced.
When you pull the tail cap off the brushes are springloaded against the armature (shaft dealy inside of motor).
To reinstall the cap put the brushes back into the holder and let the srpings hold them in place.
They will not touch the armature until you get the tail cap and brush holder started back into the motor.
Once the brushes are partly into position over the contact patch on the armature, push the brushes through so they are bearing on the armature by the srings.
Then push the tailcap all the way on and bolt it back together.
Some brushe's wires are soldered in and others are srewed in. The scewed in ones anyone could replace, the soldered ones are tougher.
  #12 (permalink)
Old 06-29-2008, 01:37 PM
David85 is gaining momentum as a positive member of FTE.
There should be 3 wires to the starter solenoid (the one right on the starter). Two large ones that provide the cranking amps and a third one that is much smaller that actually activates the solenoid. If that smaller wire is damaged, or disconnected all you will get is a click when you try and crank the engine. With a test light you should have 12V in that smaller wire with the ingition in the "start" position.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #13 (permalink)
Old 06-29-2008, 03:21 PM
AndysFords is starting off with a positive reputation.
Is it a manual? If so, roll it down a hill and pop the clutch to see if it will start.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6 w/ GearVendors Overdrive currently in a deep sleep until motor overhaul is finished. 1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual. (3) 1976 F250 Reg Cab 4x4 All 390, two C6 and one 4 spd.
  #14 (permalink)
Old 06-29-2008, 03:30 PM
yes its a manual. Another guy got the truck to run that way a week ago, so I was just going to try and fix the electrical problem since I know it runs. David, Ill check with a test light that third small wire on the solenoid like you said, and will post back.
__________________
  #15 (permalink)
Old 06-29-2008, 10:23 PM
If the starter/battery wiring is stock, you have one large wire 3/0 going down from the passenger side battery positive post.
Then you have a smaller 10 AWG wire that comes down from the relay mounted on the fender, this is the solenoid trigger wire, battery power on that wire activates the solenoid.
The other large wire on the solenoid is battery power out to the starter motor.
Some starters have a copper bus bar on the out terminal to the starter instead of a wire.
__________________
"I dig dirt"
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
