Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-27-2008, 11:10 PM
FARM69's Avatar
FARM69 is gaining momentum as a positive member of FTE.
TJ, you'd suggest that the D66 would run 40 pounds? I don't know. If I'm correct the drive pressure for the stocker are around 2:1? Thats a lot when your talking 35+.
Secondary, it sounds like the D66 is right up your alley.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / 6637 / CCV / 203 Stat
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 06-28-2008, 09:50 AM
tjbeggs's Avatar
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Bean's says the max PSI for the D66 is 40 psi. The D66 has more even drive pressures so thats why it can survive with more fuel.
__________________
Tim
Proud User of "The Cure"
1997 F-350 PSD Auto 257K
Tuned by Tony, Built by ME!
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
1/4 mile-14.59@88 MPH
Click the Picture for wiring diagrams, tech info and Pictures!
  #18 (permalink)
Old 06-28-2008, 10:00 AM
FARM69's Avatar
So it's higher than 2:1?
__________________
  #19 (permalink)
Old 06-28-2008, 10:04 AM
tjbeggs's Avatar
No the D66 is closer to 1:1. Even drive pressures would put no/little pressure on the thrust bearing. But in reality the D66 is not 1:1 So there is still a limit.
__________________
Tim
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
  #20 (permalink)
Old 06-28-2008, 10:06 AM
FARM69's Avatar
I still don't understand this drive pressure. A BB is like 1.75:2 right? The stocker is 2:1, how can the D66 be 1:1?
__________________
  #21 (permalink)
Old 06-28-2008, 10:13 AM
tjbeggs's Avatar
I don't know the exact ration but I just mean that the pressures are more equal than the stocker. One a stock turbo with a 2:1 ration it will require 30 psi exhuast drive pressure to create 15 psi boost pressure. The D66 closes that gap. Just number pulled from thin air but if the d66 is 1.5:1 it would take 22 psi exhuast drive pressure to create 15 psi boost pressure. I would guess that the d66 is closer to 1.5:1 than 1:1
__________________
Tim
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
  #22 (permalink)
Old 06-28-2008, 10:16 AM
FARM69's Avatar
Interesting. It must be harder to close that gap with bigger turbos. This almost makes me want to put a manifold pressure gauge on and see.
__________________
  #23 (permalink)
Old 06-28-2008, 10:19 AM
tjbeggs's Avatar
I will try to get some numbers for the stocker today. I am sure this has already been done but I don't want to search around to find them. Now that I think about it Neal might have done the drive pressure work once he got his BP gauge hooked up....
__________________
Tim
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
  #24 (permalink)
Old 06-28-2008, 10:22 AM
FARM69's Avatar
I know in our K-Whopper, you can peg the manifold pressure gauge out at 70. It looks pretty cool to see that needle fly to the right when you spool it up.
Neal probably does, I think I remember him talking about it.
__________________
  #25 (permalink)
Old 06-29-2008, 09:37 PM
Neal 97 250's Avatar
Neal 97 250 has a good reputation on FTE.Neal 97 250 has a good reputation on FTE.Neal 97 250 has a good reputation on FTE.
Hey Hey Hey I am here guys. I did have a BP gauge on and it seems to fill up with carbon quickly so I disconnected it. I got some info first though. I get almost the same BP as I get boost when pouring the gas to it. I have not done the comparison with the new stage II's though. I would think since the #'s are almost the same stock it is 1:1. Am I thinking right. I am learning with this thread though. It seems odd that BP and boost are almost the same.
Sorry if I got excited but I am on vacation at the beach on the front porch drink in hand and enjoying life as it should be.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
FPR,BDP 140v IDM,CCV,HPX,6637 mods
Rosewood Stage II's
6 pos. TW chip
Modded H2E
Valair full feramic clutch
6.oh Cooler
Neal's Pics
H2E install
  #26 (permalink)
Old 06-30-2008, 02:43 PM
secondarychaos's Avatar
secondarychaos is starting off with a positive reputation.
Quote:
Originally Posted by www.dieselsite.com
Exhaust backpressures or "drive pressures" as they are called in the turbocharger business plays a huge role in how much boost an engine can produce before stress on engine components fail. Drive pressure is the amount of pressure required to "drive" a certain amount of boost with a particular turbo. These numbers can usually be derived into a mathematical equation. For instance, a stock 7.3L turbo has a drive pressure approximately of a 2/1 ratio. This means for every 1 lb of boost, it takes 2 lbs of drive pressure to produce this. So, a stock turbo producing 35 lbs of boost can easily produce 70 lbs of drive pressure. The ballbearing turbos on the market estimate about a 1.75/1 ratio. That same truck with 35 lbs of boost will generate about 61.25 lbs of drive pressure.
Taken from their explanation of the h2e kit.
so what if you were trying to incorporate a second turbo later? would the d66 fail with a second turbo downstream?
Now, this turbo kit has a drive pressure close to 1/1. That means the same boost levels of 35lbs only produce approximately 35lbs of drive pressure. Your head gaskets and rods are greatly relieved of excess pressure. So, for high boost levels and high HP applications, this turbo is a must for long life of engine components
so if you can make the volume for the h2e, it'll make huge boost...
__________________
Dan- Proud owner of:
1996 Ford F250 powerstroke diesel
Running 285/75 Bridgestone dueler revos
Gauges: boost, pyro, tranny.
15.6K ICP
140V IDM mod... easy as pie (EGT's up to 1350 )
Next mod: 3" DP to 5" "sidewalk smoker" Waiting on the DP to get here.....
  #27 (permalink)
Old 06-30-2008, 10:00 PM
FARM69's Avatar
Lol. I knew I my numbers came from somewhere. Nice find SecondaryC.
__________________
  #28 (permalink)
Old 07-01-2008, 01:17 AM
mklemin's Avatar
mklemin is starting off with a positive reputation.
My question is the d66 reliable enough if i was wanting to make a semi high horsepower engine over time.all i read on here is bad mouthing it because of the thrust bearing. you think it will hold up. say i wanted to pull a sled with it sometime?
__________________
95' PSD single cab long bed 4X4 manual tranny.
New DP, 5" exaust with 5" stainless tip Sounds great no cat no muffler! Tymar intake for some bling ha! Superchips micro tuner feels good
SOON TO COME stage II's, tony wildman or dp tuner, Big oil and a pillar gauges EGT's and Boost maybe new fuel system.
  #29 (permalink)
Old 07-01-2008, 07:20 AM
FARM69's Avatar
It says its rated for up to 40lbs boost. I would assume it would be able to handle it? I'm not sure if they upgrade those bearings or not.
__________________
  #30 (permalink)
Old 07-01-2008, 08:01 AM
tjbeggs's Avatar
Quote:
If your not planning on over 400 hp/stage 2 injectors then the D66 should work well. I have been one of the largest naysayers at least on this forum of the D66 due to the stock thrust bearing (no mods done to those) mainly because I have shredded my stock turbo but the more I looking it failure I think it had more to do with the 10W30 oil I was running and the poor rebuild when it was put on with the previous owner.l
The D66 has been proven thus far to do what it is advertised to do. There are a few guys running it with stage 3 injectors and it still holding up as well. I will be using a different turbo mainly based on I can build a H2E/HX50 kit cheaper than I can buy a D66.
__________________
Tim
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
