Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-27-2008, 04:36 PM
PiePuncher is starting off with a positive reputation.
Need Help Truck not starting
Was driving down road and truck died. Left overnight and next morning truck turned over and died a block away. Thought it was crankshaft sensor and replaced that, but still doesn't work.
Motor turns but will not fire bought diagnostic computer hooked up and shows car passes no codes found.Truck will however start with a rag flashed with gas stuck in the breather. The minute rag removed truck dies.
Please Help!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-27-2008, 06:04 PM
ozx3+1's Avatar
Makes my head spin
ozx3+1 is gaining momentum as a positive member of FTE.ozx3+1 is gaining momentum as a positive member of FTE.
Please Help!
  • Fuel filters
  • HPOP
  • Other stuff related to fuel delivery that produces no codes
Is the diagnostic tool that you bought CAN-BUS compatible? If not, it'll read only the most basic of OBDII codes...
Discontinue the fuel flashing or it'll get really ugly fast.
__________________
Brian
  #3 (permalink)
Old 06-27-2008, 07:23 PM
Baddfx4 is starting off with a positive reputation.
Mine did the same thing before, I changed the filters and it runs good again, it did this to me 3 times before, I changed the filter brand from NAPA to Motorcraft and no problems for a while now.
  #4 (permalink)
Old 06-27-2008, 07:36 PM
ozx3+1's Avatar
Makes my head spin
Quote:
One of the best prices that I can find on RACOR filters (the real deal) is here RACOR PF F4604: 6.0 Powerstroke diesel filter RACOR Fuel Filter PF F4604 FITS 2003-2007 6.0 POWERSTROKE DIRECT OEM REPLACEMENT CALL FOR CASE QUANITY DISCOUNTS I buy two sets at a time. I'm good to go 30,000 miles for under $80.00, shipped!
__________________
Brian
  #5 (permalink)
Old 06-28-2008, 12:07 AM
KRDiesel's Avatar
King Ranch User
KRDiesel is gaining momentum as a positive member of FTE.
when mine did that it was a bad lift pump. It was covered under the 5/100k diesel waranty. If you do have pump problems be carefull, the injectors use fuel to cool and lube them, starving then will wipe out the injectors!
__________________
Steve Cox
2003.25 F-250 CC Powerstroke FX4 King Ranch
4" Turbo back exhaust
Ranch Hand Cattle Guard
Hollandia sunroof
K40 2000 remote radar system with dual laser
48 Gal fuel tank
Pioneer System, AVIC-D3,3 amps,12' sub, nav, DVD, TV in headrests
JOIN NEW MEXICO CHAPTER HERE!
  #6 (permalink)
Old 06-29-2008, 10:22 AM
So, if a sensor went out, I assume I would show a code with the obd hooked up? I was given new IPC sensor, Cam shaft sensor and Crank but only replaced the crankshaft sensor. (have a friend that owns a diesel parts store) I could replace sensors until my hands fall off but feel there has got to be a better way. I know it is a fuel problem and have yet to change my fuel filter. I have inspected them and while they appear fine and I can blow air through them, I guess they could be clogged enough that the pump has a problem passing fuel through them. Is the Fuel pump not a high pressure pump? If it was a filter problem, I would be shocked but then again, you guys make these trucks sound sensitive. If the fuel filters are bad, I take it that the truck will not start at all? I am getting fuel to the filter on the top of the motor or intake but not to the injectors. Anyone have any other ideas before I replace filters and then head to inspecting or replacing the HPOP. If filters dont solve the problem, is HPOP my next place to look?
  #7 (permalink)
Old 06-29-2008, 10:34 AM
One more question, Is there a sensor or something that will keep the truck from starting without the fuel filter. Wondering if you can check the problem by removing, similar to that of a gas powered car? Thanks
Keith
  #8 (permalink)
brickie is starting off with a positive reputation.
I have a lost 15 lbs of pressure, 60 down to 45 in less than a week on a fuel filter (primary) that looked clean until I cut it open. The pleats around the inside of the filter were black.I think you have a hp oil problem instead of a fuel filter / pump problem.What year is your rig and how many miles?
__________________
08/03 build 2004 350 Crew DRW 6 speed XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. AFE filter, Sct X-III, EGR delete, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper, Ride-Rite helpers.
  #9 (permalink)
Old 06-29-2008, 11:09 AM
Truck is a 2003 and have 100k on it. Just took out filters again to reinspect and they are black! Last time I checked, they looked good. Could be filters. I hope its not HPOP. Will be replacing filters regardless.
  #10 (permalink)
Old 06-29-2008, 11:27 AM
I hope for you its the filters.I had a problem with a couple of rubber o rings on the hp pump that caused a warm stall and no start until cooled down.It started as a loss of power,progressed to a stall and long restart then a stall no restart. This only took about a week from the time of loss of power to no restart. The day I fixed it the truck would run for less than 5 minutes and stall,an hour or so later it would have a long crank start and die in 5 minutes. The milage was about same as yours so if the filters don't help you have an idea where to go next.
__________________
  #11 (permalink)
Old 06-29-2008, 02:44 PM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
The ICP sensor and harness are notorious issues for 2003 year models.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #12 (permalink)
Old 06-30-2008, 08:34 AM
Replaced filters and still no start. ICP today
  #13 (permalink)
Old 06-30-2008, 08:47 AM
Have fun with that its a bitch to access.If you are going to re-re it from under the truck the heat shield has 2-10mm and one 13mm bolts.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
