Your motor for your lock is nearly seized. Its at the bottom/back of your door. You can remove it and the lock will open easily. Of course you must replace it if you want it to work. This does not explain the window. When you say the switches are fine, are they sending power and ground on to the motors?
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
