Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-26-2008, 09:08 PM
Skijeremy is starting off with a positive reputation.
1998 upper ball joint lift problem
Hey guys. I have a 1998 F150 2wd with a 3inch trailmaster lift. I have a popping noise coming from the right upper ball joint (i think). I took the truck into the shop and had the alignment done, but the mechanic came back and said that the upper ball joint couldnt be tightened anymore and was allowing play in the spindle, which is causing the popping. I have searched everywhere for a new ball joint for this lift. The problem is that trailmaster doesnt have a replacement part number for the upper ball joints. They told me to take it to a parts shop an have them look to try and match it up, but I dont have much confidence in my local shops.
The mechanic also said that the spindle would need to be replaced because over the last year that this ball joint has been loose has worn out the hole where the ball joint slides into. I am not to worried about finding a new spindle. I think I saw one on ebay for $45. I am just worried about the upper ball joint. It isnt the pressable joints like the oem, but it is a bolt in type.
Let me know what you guys think.
Skijeremy
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-27-2008, 08:16 PM
steve(ill)'s Avatar
steve(ill) is gaining momentum as a positive member of FTE.
i think you could take it to Auto Zone or NAPA and they could match it up. i also think Trailmaster is a piss poor company if they sell a lift kit and cant tell you where they got the ball joint for it!!!
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 172,000 miles
2002 Explorer 4 x 4 4.0 XLT - 105,000 miles
  #3 (permalink)
Old 06-30-2008, 06:59 PM
eallanboggs is starting off with a positive reputation.
Ball joints do NOT get tightened to take play out of them. The are NON-ADJUSTABLE. You need a new mechanic. This is unless your ball joints were not installed properly in the first place. The tapered stud on the BALL side of the ball joint must be torqued down properly during installation. If it wasn't that's not the fault of the ball joint, but that of the installer. Go back to them and complain.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
