E4OD won't shift into 3rd - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-26-2008, 08:55 PM
msuforeman msuforeman is offline
msuforeman is starting off with a positive reputation.
This afternoon truck was running fine and I came to a stop. Started going again and it won't shift into 3rd gear whether I try to start off in Drive or I try to shift the E4OD manually. It just winds up in 2nd gear and then it won't do anything more until the rpms come back down and 2nd gear catches back up and it goes again. 1st, 2nd and reverse all work fine but it just won't shift into 3rd. Got home, checked fluid and the level was good with a good color and no burnt smell, no leaking of the tranny either. By the way it is a 96 PSD F-250 with 157k. Could be anything except a messed up E4OD?????
Thanks in Advance,
Brian
Old 06-26-2008, 10:29 PM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
this sounds really obvious, but it is the 2-3 shift valve stuck in the 1-2 position. i have had 3 transmissions do this to me and that valve always gives trouble before any other ones. when the problem is still not too bad, it will do it only after the tranny warms up, then will do it more often. you will have to take the trans pan off and take the rear large valve body off and clean the valve. or take it to a transmission shop and tell them to clean the valve body and dont let them talk you into rebuilding the whole trans. i am 100% sure this is the problem
Old 06-29-2008, 09:45 PM
Thank You Sir,
Brian
Old 06-30-2008, 06:28 PM
Quote:
Mine turned out to be the solenoid pack on the transmission. This may be what you are talking about in the above statement. Everything was $250 OTD with the tranny shop doing it.
Thanks Again,
Brian
Spring E4OD issues! IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 04-21-2015 01:02 AM
1998 Ford F150 P0782 2nd - 3rd code jameskgo 1997 - 2003 F150 0 03-27-2015 05:41 PM
95 f250 7.3 deisel won't shift from 2nd to 3rd manram 1987 - 1996 F150 & Larger F-Series Trucks 13 02-05-2015 04:35 PM
'93 F150, 5.0/E4OD....no 3rd gear...HELP! Heirloom 1987 - 1996 F150 & Larger F-Series Trucks 6 07-09-2013 06:08 AM
98' F150 won't down shift Merculous 1997 - 2003 F150 2 05-21-2006 07:17 AM
Tags
2nd, 3rd, 97, e4od, expedition, explorer, ford, gear, past, powerstroke, shift, sport, trans, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
