Glow Plug Help
Old 06-26-2008, 02:40 PM
RED BOMB's Avatar
RED BOMB
RED BOMB is offline
Glow Plug Help
I HAVE HAD SOME TROUBLES WITH GLOW PLUGS
I USUALLY RUN MOTORCRAFT GLOW PLUGS BUT
I CAN'T GET THEM ANYMORE.
I HAVE HAD LOTS OF TROUBLE WITH AUTOLITE, CHAMPION, AND BOSCH THEY BURN OUT WAY TO FAST.
I ONLY GET A MONTH OR SO OUT OF THEM
DOSE ANY BODY ELSE KNOW OF A GOOD GLOW PLUG TO RUN
THAT ARE NOT SPECIAL ORDER AND MABYE HAVE A WARRANTY
EVERYTHING ON THE TRUCK CHECKS OUT OK THE GLOW PLUG CONTROLER THE VOLTAGE AND ALL THE WIRES ARE IN GOOD SHAPE
I DO PUT A LOT OF MILES ON THE TRUCK BUT IT WARMS UP BEFORE IT MOVES.
THE TRUCK RUNS 3000 TO 5000 MILES A MONTH AND DOSE PULL TRAILER MOST OF THE TIME.
BUT THIS SHOULD NOT AFFECT THE GLOW PLUGS
Old 06-26-2008, 02:55 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
The guys on the pre-powerstroke forum will tell you only to use Motorcraft or Beru glow plugs. You should be able to get them from an International dealership. Do a search on the pre-powerstroke forum and you will get lots of information.
Old 06-26-2008, 03:06 PM
RED BOMB's Avatar
RED BOMB
RED BOMB is offline
Yea I Know That Is About All You Can Run But For Some Reason The Motorcraft Or Beru Are Special Order And No One Has Them On Hand
I Tried International But They Want 27.80 A Plug And They Have To Special Order Them In .
You Would Think With All The 6.9 Out There It Would Be Easier To Find Glow Plugs
Old 06-26-2008, 04:49 PM
84-250's Avatar
84-250
84-250 is offline
check ebay, I got beru ZD11 (psd) for about $10 each
Old 06-26-2008, 05:10 PM
84-250's Avatar
84-250
84-250 is offline
sorry, i dont know if you need a spade or bullet connector, but here you go.
eBay Motors: ZD9 FORD glow plugs F2TZ-12A342-A, NEW, 8qty. (item 160255253090 end time Jun-29-08 13:27:13 PDT)
If you have a spade connector, rockauto has zd-1 for $10.17
ryanksc
03-07-2011 03:05 PM
dopedawg
06-03-2008 06:40 AM
rotory.1
09-16-2007 11:34 AM
_carlos
11-11-2006 06:30 PM
Quick Reply: Glow Plug Help
