1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
95 f-250 with 460 cold air intake
Old 06-26-2008, 11:20 AM
95 ford's Avatar
95 ford
95 ford is offline
does any one knoe where i can get one who how to custom make one
Old 06-26-2008, 04:19 PM
reddogracing's Avatar
reddogracing
reddogracing is offline
does your inlet from the filter box, go above the radiator, or down? I thought the 460 went down and to the front, so it is getting cold air from outside. If you dont have that one, just go to the junk yard, you should be able to get one cheap. What i did, with my 5.8 then i drilled a bunch of holes along the driver side of the grill to allow a little more air access. Though probably not neccesary. If you want more, pull the entire filter box and lines out and clean them up, and wrap them in plumbers insulation tape with the siler outside. Or look around the hardware, for you own idea.
I was going to use this reflective insulation, it was cheaper, and you get a bunch of it. kinda looks like sun screen for you windshield. You would have to cut it and wrap your tubes, but ti would offer more insulation. I dont think anything alse out there is going to give you colder air then that, the factory stuff that draws from the grill looks pretty good to me.
Old 06-26-2008, 04:46 PM
F TOO FITTY's Avatar
F TOO FITTY
F TOO FITTY is offline
Go with a K&N
I have a 97 F250 with 460. I bought the K&N Intake - easy to install, and you can get them lots of places online. Hope this helps...
Old 06-27-2008, 10:45 AM
REAM's Avatar
REAM
REAM is offline
I bought the K&N intake,installed it & uninstalled it.It got way terrible gas mileage,& a loud whine @ idle. It sounded cool though, like it had a cat back on it.My truck gets rotten gas mileage (10MPG)so,why add to it.
Old 06-29-2008, 05:53 PM
F TOO FITTY
Weird. The K&N intake should give you better mileage, not worse. A buddy of mine experienced that, too, though; turned out his timing was off a few degrees. Once he set the timing correctly, it gave him about 1mpg better.
1mpg doesn't sound like much, but when you go from 9 to 10, thats about a 10% increase. My truck gets about 11 average, unless I'm pulling the trailer. Then its about 9. Good thing I don't have to drive it every day...
twfs
1978 - 1996 Big Bronco
10-20-2015 04:20 AM
74FordNut
08-28-2015 11:56 PM
xc4jokestomper
18
08-06-2015 01:03 AM
DustyRoadTruckinn
18
03-13-2015 07:01 AM
95 superduty
10-16-2014 12:47 PM
Quick Reply: 95 f-250 with 460 cold air intake
