Add On CD Changer in 93 SC
I have a 93 F150 SC. Just bought an add-on CD Changer for it. I've been able to install a changer under the passenger seat in all of my other vehicles but no-go in the F150 - there isn't enough clearance (heightwise) to install it there.
I installed it over the tranny hump but I'm concerned that it's in plain sight and may wander away.
Suggestions have been:
1) Hog out some of the foam on the bottom of the seat cushion... this only works if you need an additional 1/4 inch or so, and I think I need about 1 full inch.
2) Add spacer to raise the seat.
3) Buy one of the kits to raise the rear seat and install it there.
4) Buy, or build, a floor console that would fit over the tranny hump and allow me to hide the changer. Anybody seem anything that would work?
Any comments or other ideas?
Thanks
Thanks
I myself think the best thing to do would be to raise the seats, maybe about 1-2 inches(Just to be safe). I dought it would be too noticable, and I'm sure it might be cheaper than a floor console. However, if you decided to add in a disk while you driving alone, you'll have to pull over and stop(of course). One thing I wonder about the console is how easily you can get to the changer?
I'll admit I'm no expert on car stereos, but I would prefer the seat raise instead of the console cover.
Logan
Logan
The glove box is too small to fit the changer.
I decided to get a kit that raises the rear seat 3 inches, which gives me a total of 5.5 inches of clearance - more than enough to mount the changer under it...
Even though it's a lot more work, and another $110 dollars, I figured this was the cleanest way to fix the problem. Plus I get the extra in-cab storage space.
With a 10 disc changer the fact that I'll need to stop the truck to access the changer is a minor inconvenience.
Thanks for all the suggestions - I'll post a follow-up after I get everything wrapped up.
Just thought I'd post a follow-up just in case someone has a similar question in the future.
I bought the 3.5 inch Hi Rider kit from LMI Welding
http://www.lmiwelding.com/ (no affiliation just a satisfied customer)
I seems we designed, heavy gauge metal...etc and gave me the 5.5 inches under the rear seat I needed to mount the changer.
Still plenty of romm to store other stuff too!
Overall, I think this was the cleanest, if not the cheapest approach..
Dixie95
07-28-2004 11:08 AM
Bwalk3
04-01-2003 03:17 PM
