1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Air bag light blinks!!!
Old 06-25-2008, 10:05 PM
truthseeker's Avatar
truthseeker
truthseeker is offline
When I start my car the air bag blinks 3 times then 7 times. It does this for 3 repetitions then the light just stays on. Any ideas what this means?
Old 06-25-2008, 10:20 PM
alloro's Avatar
alloro
alloro is online now
Received 4,194 Likes on 2,430 Posts
That means the airbag module has loss connection to the passenger airbag. Take a look under the passenger seat for a 2-wire connector (sometimes white tipped) and make sure it's plugged in tight.
Old 06-09-2009, 07:16 PM
tsosa's Avatar
tsosa
tsosa is offline
I had my airbag light on for two years. The dealer charged my $70 to tell me it would cost me $325.00 to get it repaired. After I read this post I looked under the passenger seat and there it was, a loose cable. I put it back in place. No more airbag light.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Thank you alloro!!<o></o>
Old 06-23-2009, 09:17 AM
mikekassouf's Avatar
mikekassouf
mikekassouf is offline
My air bag light blinks twice, then 5 times. it repeats this several times before remaining on. It might blink 3 times, then 5 times. But I am sure of the 5 times it blinks in the sequence. What does this mean? I checked the plug underneath the passenger seat. I unplugged it and replugged it, but that wasn't it. I am assuming the # of times of the blinking is a clue to what the problem is. THANKS!
03' expedition 5.4L 102,000 miles strong
Old 06-23-2009, 09:45 AM
04markIII's Avatar
04markIII
04markIII is offline
you have to get the exact flash sequence to get the right repair. mine was blinking 42, so i replaced the crash sensor and pigtail, and it went away.
Old 06-23-2009, 09:57 AM
mikekassouf
so i need to count the # of flashes before it remains solid?
Old 06-23-2009, 10:11 AM
04markIII's Avatar
04markIII
yes. mine blinked 4 times fast, then paused for a second, then 2 times fast. it repeated that sequence three times, and then stayed on solid.
Old 06-23-2009, 10:13 AM
mikekassouf
my blinked 2 times, then 5 times. and repeated this sequence 3 times. SO what's that telling me?
Old 06-23-2009, 10:19 AM
04markIII's Avatar
04markIII
code 25......brb with fault.....
Old 06-23-2009, 10:21 AM
mikekassouf
can you explain that to me a little more. I would REALLY appreciate it. Treat me like an idiot on this one. THanks
Old 06-23-2009, 10:23 AM
04markIII's Avatar
04markIII
passenger airbag deactivation switch/module(PAD) fault. not sure on what to replace/repair though. i find it odd because we don't have a deactivation switch on these 03-06 expeditions.
Old 06-23-2009, 10:38 AM
mikekassouf
I just checked the sequence again. It repeats the sequence 5 times, not 3 times. so it's 2 flashes, pause 5 flashes, and does this sequence 5 times. Now maybe this will make sense!
Old 06-23-2009, 10:40 AM
04markIII's Avatar
04markIII
still code 25 either way...
Old 06-23-2009, 10:50 AM
alloro's Avatar
alloro
Instead of a 2 and a 5 (code 25), could it be a 5 then a 2 for a code 52...Lost battery feed or low battery? This could mean that one of your airbag system fuses has blown.
Old 06-23-2009, 10:53 AM
mikekassouf
no, definitely a 2 then a 5. I've had all kind of things happen here recently. I'm going to take it to an advanced auto parts here at lunch and have them hook it up to the computer to see if it pops up a different code or if something else comes up. any other thoughts on what to do?
Quick Reply: Air bag light blinks!!!
