Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-02-2008, 03:26 PM
spinella's Avatar
spinella spinella is offline
2000 Ford F-350
spinella is gaining momentum as a positive member of FTE. spinella is gaining momentum as a positive member of FTE.
if you do change out your gears let us know how much of a difference it made,and again give your son the beer AFTER he does the job.
__________________
2000 f350 v10 lariet-A.R.E. cap
front mounted hidden hitch
SCT -X2 5 STAR TUNING-S&B CAI
2009 wheels and tires-superlift leveling kit
firestone air bags-bilstein shocks
  #32 (permalink)
Old 07-02-2008, 05:24 PM
super 6.8 super 6.8 is offline
super 6.8 is starting off with a positive reputation.
Quote:
Originally Posted by SuperDutyGuy06 View Post
Don't want to say your wrong....but your wrong,I have a rearend shop,been doing it for 20+ years,every set whether Ford OEM or not need depth shimed and pattern adjusted to be right and not make noise and be reliable,8.8s are probably the most forgiving using the same pinion shim and them coming out ok IF your Lucky! It's like anything else,theres a correct way a throw it together and see way and the wrong way.....two good quality ring and pinion sets for a 4X4 are 5-600.00 and all the instalation parts,plus if it has 60k or more on it I change all the bearings,it foolish not to...and yes it's about 2000.00 to do two rears the RIGHT way.
I guess that is just some "professional's way of making a little more money.
I have seen several R & R'd gear sets with the same shims go well over 100k miles.
There is some leeway on installation. Why is the backlash spec so loose? If you can be between 8 to 15 thousands and be ok, there is some leeway. The shims do not have to put you right on the money.
Whatever .....
__________________
2007 F250 CC 4wd v10 4:30 5 sp auto with moonroof
2002 Mountaineer 4.0 5 sp auto
1996 Explorer Sport 4wd 4.0 auto
1999 Ranger 3.0 2wd 4 sp auto (wrecked)
1993 Mustang 5.0 supercharged (sold)
1999 F250 V10 Superduty (sold)
  #33 (permalink)
Old 07-02-2008, 07:45 PM
SuperDutyGuy06 SuperDutyGuy06 is offline
SuperDutyGuy06 is starting off with a positive reputation.
Whatever .....
Well in 20+ years of doing this,2-4 rears a WEEK...maybe 5000+ sets of gears or more and I'll bet I haven't used the same pinion shim two dozen times,you must be a lot better than me,I do most of the dealers work aroud here because most guys in a dealership can't do them RIGHT,I know I worked in dealerships for years,as stated above I see it all the time when someone that doesn't know what there doing screws one up and has to buy gears again and start all over again....and no it ain't rocket science,but like alot of things there is a right way,and when you do it everyday and your shops reputation is on the line,why would I just slap them together and hope it's ok?
  #34 (permalink)
Old 07-02-2008, 08:05 PM
Easy man,
I am not knocking you. The main difference is you do it for a living (with your reputation on the line) and I do it to save money.
In my limited experience (with 8.8's) I have never had a problem. It just seems that a lot of people that are decent mechanics will shy away from doing gears. I don't think they are that difficult if you pay attention to what you are doing.
I can see how a guy like you that does thousands of them would get pretty good at it. How long does it take you per axle? I remember my first one took me about 2 days. lol
Oh, about replacing the bearings with only 60k miles. Those things will last en excess of 200k with just fluid changes. Is that really necessary?
__________________
  #35 (permalink)
Old 07-02-2008, 10:48 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation.
Let's not let this turn into a pissing contest, the original poster sure doesn't need it If you want to argue about this sort of thing, you can take it to the driveline forum here on this site ...
I sorta agree with one side, and sorta agree with the other.
In one way, you can re-use the original shim pack thickness, IF you use new bearings, because that's the way they are setup from the factory.
On the other hand, you CAN get away with using the original bearings, but you SHOULD check everything afterwards.
The point I don't get is, how so many people can reuse the original shims AND get a good pattern.
To SuperDutyGuy06, do you EVER use the originals, check them, and wind up getting a bad pattern?
Or do you just start fresh on each and every one and never bother checking it?
Or, worse, do you use non-original bearings like NTN (vs. Timken) and wind up with varying setups because the bearings themselves are not all that perfect each and every time?
Because, again, I've setup quite a few for a shade-tree mechanic, and every time I reuse the original shims, I've found the pattern to be perfect. Except, as I already stated, where the housing was beaten to death to begin with...
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #36 (permalink)
Old 07-06-2008, 07:26 PM
Not sure if you are talking about rebuilding a rear or setting up a new ring and pinion from the start,so I'll just exsplain what I do,don't want an argument either but I see so many guys ruin a good ring and pinion by not doing it right. On a rebuild situation I just put new Tinkens in ,set the pinion preload and check backlash and ALWAYS use original pinion shim,once in a long time you may have to reshim for backlash,timkens are really consistent and I feel are about the best out there.I NEVER put a new set of gears in without a bearing kit,one of the reasons for that is I rebuild so many "street vehicles",Jeep Cherokees,1500 Chevys,1500 Dodges & 8.8s......for howling,mainly over 100k miles but as little as 50k and the pinion brgs. are bad and the rear howls with on off thottle,and you won't believe how small imperfections can cause that much noise,so when installing a new 200.00-400.00 ring and pinion that can NOT make any noise at all for the customer it would be silly not to spend 100.00-200.00 for a bearing kit that comes with crush collar,pinion seal,and pinion nut.When setting up a new ring and pinion I AWAYS start with original shim,but to get the most Ideal pattern to have NO howl at any speed and be reliable I only remember a handfull that had a perfect pattern right off the bat,and contrary to someones prior comment as an opportunity to charge more money to make it perfect,I charge a flat price whether I have it apart 4 times or once.I do a LOT of dirt circle track gears and sometimes do not change carrier bearings.AWAYS change all for drag race gears as the loads are severe with trans brakes especially.Yes you can use all old bearings and throw old pinion shim in and it comes out "OK" sometimes but is it completely quiet,no noise? And so many guys buy these cheap crap gears at Summit and other places and you might ad .10-.15 to the orginal pinion shim just to get it even close,as anything else when you do it every day you learn tricks to make up for housing machine differences and crappy gear quality from someone bringing me their own parts.My WHOLE point from the beginning of my comments in this thread is to keep some poor guy from spending a pile of money for new parts and someone make him think if he just "replaces" his gears,in a couple hours and everything will be just fine and he ruins his new parts and possible others and has to start all over again......because I see it happen over and over again.....just trying to help shed a little knowledge and help here thats all.
  #37 (permalink)
Old 07-07-2008, 09:35 AM
supeRobertduty supeRobertduty is offline
supeRobertduty is starting off with a positive reputation.
Quote:"My WHOLE point from the beginning of my comments in this thread is to keep some poor guy from spending a pile of money for new parts and someone make him think if he just "replaces" his gears,in a couple hours and everything will be just fine and he ruins his new parts and possible others and has to start all over again......because I see it happen over and over again.....just trying to help shed a little knowledge and help here thats all."
Yes ,I agree 100% on above as was my intentions also:
But I am finding most people do not like the truth and want to be told lies
"Sure you can do it, gears are easy" "American cars are the best" "I did not inhale"
"I allway's hide money in the freezer" .
Never underestimate the power of deniel
  #38 (permalink)
Old 07-07-2008, 11:20 AM
rvpuller rvpuller is offline
rvpuller is starting off with a positive reputation.
Quote:
Originally Posted by bama210 View Post
and I can't decide which ratio would be best. I have it narrowed down to the 4.30 or the 4.56. I've been driving the V10 for 4 months now and judging by the way it pulls my boat I'm afraid it may not have the umphh to pull the 36ft 5th wheel which weighs in at 12,600 lbs. It has the 4.10 gears in it now.
Any thoughts? Thanks.
Wendell
I have been pulling with 4.30 gears for 8 years and they have worked great for me but you have the newer 17" tires on your truck so would have to go to the 4.56 gears to get the same final gears that I have. If I was buying a new truck today I would have the 4.56 or even 4.88 installed form day one.
Denny
__________________
2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
2003 HH Premier 35 FKTG
BSEG started 4/15/2000
  #39 (permalink)
Old 10-06-2009, 06:00 AM
hlozano hlozano is offline
hlozano is starting off with a positive reputation.
Pretty cool article regarding rear ends.
Ford 9 Inch Rear End Upgrade - Ring And Pinion Gear Set - Truckin' Magazine
__________________
2002 Ford F250 XLT Supercab 2WD V10, 3.73 rear end, Auto, Shortbed
2003 Salem 28' Model BHSS Fifth Wheel
  #40 (permalink)
Old 10-06-2009, 07:00 PM
redwing22 redwing22 is offline
redwing22 is starting off with a positive reputation.
Quote:
Denny
RVPuller: Now you got me thinking, bought a new 09 350 cc4x4 with 4.10 rears will it pull my new 5er that weighs 9000 empty.Tell me Tell me inquiring minds want to know!
  #41 (permalink)
Old 10-07-2009, 07:32 AM
Quote:
You will have no problems at all, our trailer is a 16K 5ver 24K gross tuck and trailer and we pull it with 2V V10 all over the country including high mountain passes in Colorado. I do wish I had the 5 speed transmission like you do for the big hills .
Denny
__________________
Air Lifts 4X2
  #42 (permalink)
Old 10-07-2009, 04:01 PM
Thanks RV Puller was wondering. could have got one with 4.30 but backed off thinking fuel milage would really suck. So I got 4.10 instead.
  #43 (permalink)
Old 10-12-2009, 11:47 AM
PhotoJoe PhotoJoe is offline
PhotoJoe is starting off with a positive reputation.
I bought my X used with 46,000 miles. It came with 3.73's. While towing my 29' TT (8500 lbs.), that thing hunted for gears something fierce with the slightest rolling hills. Stock tires are 265's and I have 285's. I paid $550 (2wd) and went to 4:30's. NIGHT AND DAY better. And my mpg didn't drop more than 1 mpg in the city, maybe just a touch more than that empty on the highway, but we hardly ever run highway with it without the trailer, so I don't care about that.
__________________
Joe Photo
2002 Excursion Limited
V10 - 4.30's
  #44 (permalink)
Old 10-27-2009, 03:55 PM
wfof250v10's Avatar
wfof250v10 wfof250v10 is offline
wfof250v10 is starting off with a positive reputation.
Quote:
DIDO......now when I hit a steep hill lets say 8% grade I just throw the R400 into 2nd gear and rev the rpm's to 3,500 to 4,000 and can pretty much maintain 55 to 60mph with no problem.
__________________
04 F250 SD Supcab, V10 4X4, Volant CAI, 4.30's
86 Ranger V6 4X4
66 Mustang 289 4 speed
05 Colorado 34' 5th
  #45 (permalink)
Old 10-27-2009, 07:28 PM
1ViciousGSX's Avatar
1ViciousGSX 1ViciousGSX is offline
1ViciousGSX is starting off with a positive reputation.
Question?
If you have 3:73 gearing and the 4R100, and you turn overdrive off, what rear ratio does that compare to if you were in overdrive with a higher gear rear end?
__________________
My F350 Super Duty & 1ViciousGSX
2001 F350SD XLT SC LB DRW, 6.8L V10, Auto, 3:73, Loaded, 11200lb GVWR, 17000lb GCWR, Factory Camper Package, 5-Star Tuning SCT LiveWire, Volant CAI, Magnaflow Muffler, SPD Y-pipe mod, 4 inch Stainless tip, MKM Customs grill update, Clear corner lamps, Line-X, RBW 5th-wheel, Reese flip up ball
Tags
1999 , 2001 , 2008 , change , f250 , f350 , ford , gear , gears , pinion , ratios , ring , truck , v10 , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
