HOWTO - 87-96 A-pillar gauge pods on 80-86 trucks - Ford Truck Enthusiasts Forums
Old 06-25-2008, 12:24 PM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
rmalottwtes30 is gaining momentum as a positive member of FTE.
I got my pod almost done. This pod started out as a 92-97 Ford. I cut the top and bottom off the pod. I bought the pod from Glow Shift. (Good company to deal with.) The plastic isn't really the same measurements as my a pillar post so I had to do a little twisting to get it to fit on to my column trim. Since it was a little twisted using glue was out of option cause of the tension on it so I broke out my fiberglass and resin and Bondo and went to work. I did a few test fits today and the bottom pod clears the dash by like a quarter inch. I plan on having this thing finished by doing some more sanding and final touch up and a shot of paint. I will get more pictures once I get the pod installed on the truck.
This is how it started
NOW
Close up of how it fits together
Old 06-25-2008, 12:49 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Very nice work.
Old 06-26-2008, 08:04 AM
Oscar Meier Oscar Meier is offline
Oscar Meier is starting off with a positive reputation.
Super Job - nice matching to the '85 trim.
Old 06-26-2008, 10:05 AM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE.uncle.stosh has a good reputation on FTE.
I don't know how you are going to be able to view any gauges in there. It looks like the cups are too vertical.
Old 06-26-2008, 10:10 AM
I did a test fit after I got all the fiberglass and bondo work done, the gauges are easy to see, I will post a picture once I get it on permanently, the trim for the A-pillar goes at a pretty good angle.
Old 06-26-2008, 10:42 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
That should have fit pretty well to begin with. I used a pod for a 87-96 ford in my 85 and the only thing is the mounting surface is round while the pillar trim has an angle. The gap is barely noticeable though. I just attached it with double sided tape. Looks like you're going the extra mile though, good luck.
Old 07-01-2008, 01:56 PM
I got it done, Ive had a few compliments so far on it. Right now im running the amp gauge, oil pressure, and water temperature. I plan on ditching the amp gauge and getting a EGT gauge to replace it on the top pod. At first I had the oil on top but the thing was lacking length to be able to hook it up on the back of the engine. After I get my EGT I am going to replace the other 2 gauges with gauges identical to the EGT.
Here is what I am going to replace the gauges with..
Should I go digital or not?
Here is the pod installed and finished
Old 07-01-2008, 09:00 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Looks wicked .....
Old 07-02-2008, 10:53 AM
Nice job, looks pretty seamless.
Old 06-16-2014, 01:02 PM
JordanL91's Avatar
JordanL91 JordanL91 is offline
JordanL91 is starting off with a positive reputation.
My buddy used to be sponsored by Carsponsors.com and he had that exact same set up. He used to love his Glow Shift gauges, granted he put it in his older M3 but Ive heard good things from these, Thanks for the post!
Hood Insulation rmalottwtes30 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-15-2011 02:43 PM
Wiring Garage Outlets rmalottwtes30 General NON-Automotive Conversation 17 10-05-2011 09:47 AM
92 pod on my 85 almost done rmalottwtes30 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 02-21-2011 11:06 PM
HOWTO - Front clip swap ctubutis '80-'86 HOWTO's 0 02-13-2011 11:53 AM
Updating to 94 Front Clip rmalottwtes30 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 40 11-09-2010 12:08 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
