Checking out a 1948 F4 This weekend!!!
Im going to take a look at a 1948 F4 this weekend and I dont really know prices on old trucks. It is a fully operational farm truck with a working flatbed dump. Also has a working flat head V8 which im guessing is probably original but dont know for sure. The only rust it has is a baseball size spot of surface rust and thats it. It does need new kingpins some minor brake work all which i can do in my own garage. The right front fender has a dent in it too from a tree branch that fell but doesnt look bad either. New tires on the rear too.
Is this worth $1200 bucks
Bryan Swenson
Bryan Swenson
Before investing too much, check for a title. Titles on farm truck are sometimes non-existant. Depending upon your state DMV laws, title could be impossible to obtain.
If it has a title or if your state is fairly easy to obtain a title then the deal sounds good. If there is no title and your in a state that's hard or impossible to get a title then you need to take that into concideration on how much you want to spend on a truck you may never get to drive out on the road.
I bring up this subject every time someone mentions they are going to buy a big truck. The very first thing you have to think about are the wheels. If the truck has stock wheels it will have either 18" wheels, if it came from the factory with duals on the back, and 20" wheels, if it came from the factory with single rear wheel. I have found that most F-4 either switched the 18s for 20s or added an additional 20" wheel on each rear wheel. Either way, if the truck has stock wheels it will have the Ford "Widow Maker" type wheels. These wheels are of such bad design you will be hard pressed to find someone who will work on them. Do a search of this site for "Widow Makers" and you'll find a lot of information about them. You'll have to find replacements which are a bit difficult to find. Read this link on my web site to get more information:
Ford two piece rims
Ok, now onto your truck. If it's as nice as you stated $1200 doesn't sound bad at all. Lately with the price of scrape steel and shows like Barret Jackson Auction the price of old iron has sky rocketed. Check the frame, unlike the larger F-5 & 6, the F-4 has a single layer frame and is not prone to the layers collecting rust and separating. There were fewer F-4s made than the F-5 & 6. I think this was because they weren't big enough to haul heavy loads and were too big to haul the small loads. I personally think they're a great "big" truck to restore because they're lighter weight and don't have the frame rust issues that the larger trucks have. Plus, as I stated, there were fewer made.
Good luck and post some pictures as soon as you can.
Ford two piece rims
I don't think you should waste your time with a relic like that. I'd pass on it.
BTW, where did you say it was. I mean, if you could PM me with the name of the seller I'll do my best to prevent the next poor sole from being suckered into such a deal.
Nice truck, I'm really jealous, I can only find beat up crates. That'll be $1200 well spent, enjoy.
