Suggest a stroker kit for my '70 429 (d0ve-c heads)
Appearently you don't realize that D0VE heads are basic passenger car castings and a little confused as to what they actually are. They are NOT cj or performance heads thus they use the exact same valve size as D2VE and D3VE heads. So if you would NEED to increase the valve size on one you would need to on both. And yes you can use the CJ valve sizes on either head just fine.
I would at a min increase the exhaust side to 1.71 as the exhaust is the major restriction anyway, but even on a work engine I personally would go ahead and do both, I don't think the intake would really be necessary on a <5000rpm engine but I don't think it's going to hurt you in the least on a stroker. JMHO
could the stock sizes support a 521? on a low rpm truck engine I would say definitely maybe. With some clean up work yeah they would support it but if your replacing valves anyway why not go ahead with the slightly bigger. (once again personal opinioin but I think replacing the valves is a good idea just for safety sake, instead of living with 20+yr old 2 piece valves, decent stainless units from ferrerra really aren't that expensive anymore until you get into the race stuff of series 6000 and above)
Monsterford34
10-08-2013 06:33 PM
Jimmyrig
23
09-29-2013 04:53 PM
Myfreeford
04-14-2013 07:04 AM
Dyerstown
37
12-17-2002 11:24 PM
