Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-24-2008, 05:48 PM
txdeerhunter is starting off with a positive reputation.
airbag light stays on
I replaced my radio the other day. Now my airbag light is on. I think it is flashing 2 times then 7 time. Does anyone know what the problem could be?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-24-2008, 06:16 PM
ranger88a is starting off with a positive reputation.
check the pass disable switch.
__________________
20+ years as a tech. Diesel certified.
  #3 (permalink)
Old 06-24-2008, 06:18 PM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
You bumped the bulb in the PAD and broke the filament.
If you can solder, two bucks or so at Radio Shack.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 06-24-2008, 06:21 PM
I looked at the bulb and it looks fine.
  #5 (permalink)
Old 06-24-2008, 07:17 PM
sheetsd66 is starting off with a positive reputation.
I got the same code and it was a bad bulb in the PAD. Make sure it got plugged back in good and none of the pins were damaged. If it checks out, try this:
http://www.ford-trucks.com/forums/13...lightning.html
  #6 (permalink)
Old 06-24-2008, 07:20 PM
You can also do a search on this forum under "airbag code 27" and find instructions and part numbers for LED bulbs without the resistor.
  #7 (permalink)
Old 06-24-2008, 07:27 PM
Quote:
Looking at it doesn't tell you anything useful.
The bulb is now open and needs replacement.
Steve
__________________
  #8 (permalink)
Old 06-24-2008, 11:31 PM
I did not find any forms that just had the LED. Can any one help. When I search I find the same post.
  #9 (permalink)
Old 06-25-2008, 07:41 AM
SEARCH keywords "+PAD +LED +RADIO +SHACK"
Steve
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
