Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-24-2008, 04:38 PM
Dre82s is starting off with a positive reputation.
Egr!!!
Truck is shooting code 32 on the scanner which means EGR now where in the hell is the EGR???
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-24-2008, 06:25 PM
bluesman2333's Avatar
bluesman2333 is starting off with a positive reputation.
Could be anywhere or nowhere. What kind of truck do you have?
__________________
1993 F150 302 somesortofautomatic. F350 front springs, bed liner, tool box, ugly tail gate. One thing you can say about a F series truck is it's as aerodynamic as a brick, turned sideways.
  #3 (permalink)
Old 06-24-2008, 06:27 PM
60F100 is starting off with a positive reputation.
What engine do you have. On the 5.0 I believe it come from under the intake plenum to the throttle body. The valve should be near the throttle body. I believe it is shown in the Hayne's manual
  #4 (permalink)
Old 06-24-2008, 09:06 PM
icrman is starting off with a positive reputation.
Just look for a metal tube that runs from one of the exhaust manifolds to the intake manifold area, then you will find it, as that tube will go right into it. Can be different on some models though.
__________________
1996 F-250, XLT 460 E4OD, Long box, Supercab 4X4, 4.10 Axle Ratio, Camper and tow package.
Self install of: Clifford alarm, B&W Flipover gooseneck hitch, Ride Rite airbags, and compressor system, Prodigy Brake controller.
  #5 (permalink)
Old 06-24-2008, 11:45 PM
I have a F250 5.0 1988 oh ok could the egr valve be the reason why my idle is so high and the reason for a high amount of carbon build up in the intake?
  #6 (permalink)
Old 06-25-2008, 07:44 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Yes, or maybe the EGR tube is broken, it runs from underneath the upper intake to the valve that's on the left side of the throttlebody.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #7 (permalink)
Old 06-25-2008, 08:37 AM
no can I by pass that since I live in florida dont really thing I need the warmth of the exaust in my engine its 85 at night here in miami!
  #8 (permalink)
Old 06-25-2008, 09:07 AM
Conanski's Avatar
Not without throwing codes and causing drivability problems, the EGR actually helps improve milage as well.
__________________
Paul O
  #9 (permalink)
Old 07-01-2008, 10:18 PM
How should I go about trouble shooting my Egr, if there is no vaccum will it be shut or open, should I go ahead and replace it since its an original part 88 part. or should I try to get it unstuck. 10 mpg is killing me here in miami fl.
  #10 (permalink)
Old 07-01-2008, 11:09 PM
skaterbro is starting off with a positive reputation.
I haven't read anywhere about you actually checking the vacuum lines. Being a '88 i'm sure those lines are weak and probably broken somewhere.
__________________
1993 F-150 XLT, 2WD, 302, E4OD, 8.8
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
