Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-24-2008, 02:53 PM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
Garage is empty, add now
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
Help crack in the block
We pulled my 53 flathead 8 out of the tank today and discovered a crack between the water jacked and one of the head bolt holes. Is this a problem? My re-build guy says he has gotten conflicting answers...
I'm thinking as long as the bolt can torque the head down then there shouldn't be any water problem? He suggested using a stud with sealer on this particular hole. He felt that would work, but suggested we ask the experts here.
Thanks in advance.
__________________
Steve
53 F100 Flathead 8
Listen to advice and accept instruction, that you may gain wisdom for the future.
Proverbs 19:20
  #2 (permalink)
Old 06-25-2008, 12:48 AM
Snowking's Avatar
Snowking Snowking is offline
1950 Mercury M47
Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.
I don't think thats a problem, not unless the crack exceeds to a cylinder wall. When you bolt on the heads use thread sealant.
No that's not a problem because each bolt that holds down the heads IS A PART of the water jacket.
__________________
Some nights you just have to realize your gonna be slaying a Dragon and not saving the Princess
  #3 (permalink)
Old 06-26-2008, 12:08 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
My engine shop, which has extensive experience with flatheads, advised me to helicoil my two cracked bolt holes and use a sealant on the threads. He says they have done that for years with success.
Good luck with it
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #4 (permalink)
Old 06-26-2008, 08:32 AM
Ego Flat 48 Ego Flat 48 is offline
Ego Flat 48 is starting off with a positive reputation.
ssj7kids;
You and I seem to be at the same stage of the game on our engines. I have a '49 239 and also have what looks like two cracks, one on each side at the same location. I pulled the heads off and was doing perfect until my wife came out and starting swimming in the nude. Needless to say, I was distracted...Whats your next step? I don't know if I should put new pistons and rings or not. TTYL. Ralph
  #5 (permalink)
Old 07-01-2008, 11:12 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.
ask number dummy those cracks are so common they have a part no . or so i'm told !
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!! if you don't have 2 or 3 broken fords / projects , then you just ain't right !!!!!!!!!!!!!!!!
  #6 (permalink)
Old 07-03-2008, 03:06 PM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
yeah, it's so common it's almost like cracks were part of the manufacturing process!!! any GOOD machine shop should be able to fix this if not TOO severe!
  #7 (permalink)
Old 07-07-2008, 12:16 PM
rcav8or's Avatar
rcav8or rcav8or is offline
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
I wouldn't even bother to try to fix them - virtually every block has them. You could possibly make things worse, by attempting to repair - it has actually relieved a little bit of stress there, plus, because of where it is, it doesn't affect anything. The only thing I've found, is that since it can allow water to get in the bottom of the stud hole, that stud or bolt can be VERY hard to get out...my studs broke both sides, and they were the only ones that broke - the rest came out fairly easily.
I wouldn't worry about it. I know it goes against our nature, but it's ok...really it is....
R
__________________
Roger Phillips
Oxford, IN
Click the link for pictures of my truck:
1951 Ford F2
  #8 (permalink)
Old 07-07-2008, 12:17 PM
rcav8or's Avatar
Quote:
Originally Posted by Ego Flat 48 View Post
ssj7kids;
Ralph - what's your address, and do you have a tall fence??!!??
Ha, ha!!
Seriously, sounds like a great time for a "break"...
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
