higher radiator cap pressure
Old 07-03-2008, 06:48 PM
55 f350's Avatar
55 f350
55 f350 is offline
ok guys i'll ask this here where im more likely to get an answer eventually ..... i am going to have my radiator recored and the tank patched or replcaed { it popped a seam } and replace the water pumps . what i wanna know is after i double check everything including running a compression check / leak down test , and i'm sure its all ok what pressure of a cap do you think i can use without issue . i'm thinking about jumping up to a 7 or 9 pound cap . i used to do this on other old rides as a way to raise the boiling point of the coolant . so ..................................
Old 07-03-2008, 07:11 PM
petey shoes's Avatar
petey shoes
petey shoes is offline
are you REALLY expecting to run truck that hard? if system is in good or better than good condition, you should have no over heating problem. i don't think you will hurt anything, but, what are you going to gain?
Old 07-04-2008, 08:55 AM
55 f350's Avatar
55 f350
55 f350 is offline
naw petey aint gonna run it that hard . gotta remember im still a bit of a flatty rookie . my mind still works in the late model frame most of the time . it gets pretty warm here and was thinking it might be a good thing to raise the boiling point , but thats why i asked so i could here from you guys . so it sounds like a goofy idea , so we dont do it and move ahead .
Old 07-04-2008, 04:45 PM
arnbobold's Avatar
arnbobold
arnbobold is offline
I've got two words for you: Wetter Water. Ever heard or used it? I've run it in all my vehicles. O'reilly's or Auto-Zone should have it, go see and read the bottle. I would
think just a good cap would be fine. Better than a rag, which I used when I was a pup.
How many blades are on your fan? Maybe try finding one with more blades. Bob
hotrodjohn71
04-25-2016 11:22 AM
52 USCG Panel
15
03-22-2016 08:24 PM
86pullerf350
25
03-03-2016 12:35 PM
hoss73ford
06-21-2015 08:15 PM
wannabronco
13
12-11-2004 03:47 PM
Quick Reply: higher radiator cap pressure
