help! stranded 30 miles from home, oil leaking, white smoke
truck is stranded, can't see what's actually leaking. looks like it's oil coming from behind the fuel bowl somewhere. oil is sitting on the top of the fuel filter cap. any insight as to what it may be? middle man, messaging back and forth - to speak with stranded truck driver, please call 660-651-6505. otherwise, i'll be checking back every few minutes. thanks!
__________________
Dustan
1999.5 F350 7.3 Power Stroke Crew Cab 4x4 Long bed
Zperformance 90hp 6 setting module, AFE 4" turbo back exhaust, diy 6637 filter, stancor gpr, LT275/70R18, 3 pod pillar gauges, CCV mod, euro lights, hpx PAA Member #51 http://www.ford-trucks.com/user_gall...9/189591.80.80
__________________ Mark
Above car featured in Sept. '83 Super
Stock & Drag Illustrated. No longer mine.
1999.5 F-250 2x4 Extended Cab Long Bed
209,351+miles
6637 Mod
4 inch SS Straight Pipe
DP Oh Boy! Need I say more?
PhD In Common Sense & Logicality
University of Hard Knocks
Relax for a minute. We have lots of MO. members but this is a bad time of day to be in trouble. How far are you from St. Louis?
209,351+miles
6637 Mod
You really did not give much info. Is the truck still running, or did it quit? If it has blown oil everywhere it will be low on the dipstick. At least check that and get back.
209,351+miles
6637 Mod
Blown HPOP line or seal is my guess from the description of the problem.
Not much to do but tow it in and get if fixed.
I could be 300 miles, not 30.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice. God and Dog
oil pressure gauge was reading normal before hand. truck started blowing white smoke, had really low power, then died and he had to coast into a gas station parking lot. truck will not restart now, so no way to check oil pressure. nothing is showing on the dipstick.
__________________
Dustan
What Dan said, don't even dream about cranking it anymore. It's what I would have said too on my first reply if I'd had a little more info to work with.
209,351+miles
6637 Mod
I agree, if you have oil on top of your fuel filter lid, its spraying and likely a HPOP line that burst or blew off the port.
__________________ Greg .. Dyno'ed 561 HP on 08/22/09
2002 Ford F350 4wd, Built motor, custom cam, comp 910's, DI pushrods, H-11 headstuds, Casserly hybrids injectors, Garrett GT42 turbo, Terminator dual HPOP's , BTS Transmission, Tru Trac rear, ITP regulated return w/fuel bowl delete, Walbro fuel pump, Airdog fuel separator, coated exhuast manifolds, Diesel Performance Products Intercooler, ATI Damper, Melling LPOP, LIVE TUNED by Jody Tipton!!
Well it's me typing now, my wife was relaying the information for me earlier...
Right you are my friend.
Quote:
By looking at the top of the engine i still can't tell where it came from but one of the hpop lines seems very wobbly when i was looking around it.
The lines are braided.
Should i dump some cheap oil in it to get the level up to see exactly where it is coming from or just change both lines and change/add the right oil and see if she starts.
__________________
Dustan
All you need to do is fill the HPOP and crank it over to find the leak. I wouldn't refill the entire crankcase right now. But, I WOULD pull the IDM relay to insure it doesn't start with no oil in it.
But, STAND BACK!
Pop
__________________ -Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX. Email SpringerPop
Question for the gurus, why all the white smoke? The last time I saw white smoke pouring out of my exhaust, I had blown my turbo seals and the smoke was oil hitting the exhaust. I had oil on the outside of the turbo, EBPV and a few other places but not as far forward as the fuel filter.
Don't forget to throw some plastic down on your driveway if you plan on making it leak again.
I know it's a pain, but look at the bright side. Your engine died because it was low on oil. That's better than being able to drive it with no oil in the engine and causing much bigger problems.
Who's the friend? Is he a member here? If so we need to say thanks to him.
If i can remember correctly when my tractor ran out of fuel(bad gauge) once i got fuel back in there i had to prime the system and smoke a little black and white smoke can out until it was totaly primed. I can remember white smoke but prolly both, long time ago..
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
