Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-24-2008, 07:23 AM
flipklos is starting off with a positive reputation.
What kinda Milage does your Y get?
My stock 64 292with a 4 spd t-98 gets about 13. Annyone get better?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-24-2008, 08:47 AM
THX1138-Z is starting off with a positive reputation.
What rear gear do you have?
  #3 (permalink)
Old 06-24-2008, 11:11 AM
46yblock is starting off with a positive reputation.
My older engine was 16 mpg, but it was running extremely inefficiently due to the low compression. It should be 22 plus with the new motor and its 9 to 1 CR. Truck has been lightened to 2750 lbs, and 3.00 rear. Very mild cam.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #4 (permalink)
Old 06-24-2008, 02:46 PM
4.10 rearend. I think Ill go to a 3.89 posi setup in a few years. 16 would make me happy.
  #5 (permalink)
Old 06-25-2008, 09:08 AM
Joe Johnston is starting off with a positive reputation.
Mileage
Had a 55 T-Bird 292. 2 bbl, 3 spd overdrive and consistantly was in upper 20's when on the hwy. Later had a 56 with dual quads automatic and 14 was about tops, but the 56 was more fun to drive!
  #6 (permalink)
Old 06-25-2008, 10:12 AM
juterbock is starting off with a positive reputation.
My 61 f100 with rebuilt stock 292, 2bbl, 3spd, 2wd and 3.70 gears ran about 20mpg and that was with me rebuilding and adjusting the carb at age 15. I would imagine it could have done better if I had know what I was doing or paid someone else to do it who did.
__________________
If you EVER think something you are about to do is a dumb idea and will cost you a lot of money when it falls apart; it WILL!!
2001 F-250SD V10-BSEG 5-Speed Stick, Manual 4X4, 4.30LS SC SB XL - Bilstein HDs
1999 F-150 V6 Auto XLT - Traded
1988 F-250 351W Auto 4x4 - Sold
1961 F-100 292 Y-8 3-Speed Unibody, Custom Cab - Gave Away
  #7 (permalink)
Old 06-25-2008, 10:19 PM
LiftTech is starting off with a positive reputation.
'56 F-350 dually, weighs about 5800 pounds. Four speed, 4.86 gears, 272 with a 2 barrel, averaged 13 MPG at 55 MPH this past weekend.
__________________
1956 F-350, dually with a hydraulic dump Ford flatbed, daily driven.
"Measure your wealth not by the things you have but by the things for which you would not take money."
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
