1986 F350 with dually rear brake drum removal question. - Ford Truck Enthusiasts Forums
Old 06-23-2008, 09:35 PM
damzish damzish is offline
damzish is starting off with a positive reputation.
I am working on a 1986 F350 with a dual rear end and I need to remove the drums for inspection.
I have the axil removed and I'm looking at the nut holding the bearings in and it is rounded (not a hex nut) and flat with 4 square holes in it. Any suggestions on what tool I would use to get this spindle nut off with?
Any steps that I should know about before attempting to spin the nut after I get the tool?
Thanks for any replies I get.
Pull Rear Break Drum? fridgeddiesel 1994.5 - 1997 7.3L Power Stroke Diesel 7 10-18-2013 12:14 PM
1970 F250 rear brake drum removal dlo3575 1967 - 1972 F-100 & Larger F-Series Trucks 5 12-12-2011 09:41 AM
Axle Nut size on '86 F350 Woodlums 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-08-2009 01:04 AM
94 dually drum brakes removal 94' 460 F350 1987 - 1996 F150 & Larger F-Series Trucks 9 09-07-2007 11:01 PM
Rear Brake drums jboard 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-10-2006 09:41 PM
Tags
1986, brake, brakes, drum, drums, dually, f350, ford, obs, powerstroke, rear, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
