Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2008, 07:41 PM
TimV TimV is offline
TimV is starting off with a positive reputation.
Solution for stuck front rotors
In case anyone runs into this:
I waited far to long to replace the rotors on the front of my wife's '04 Escape.
They were original and rusted pretty bad after 63,000 miles. After beating on them for awhile with a small (2lb) sledge hammer, it seemed that they were welded to the hubs.
I finally broke out my angle grinder and with a cutting wheel, cut the rotor off about 1/4" back from the face around the edge. This cut was even with the back of the face of the hub and was pretty fast and easy.
I thought that the rotor would be rusted to the face of the hub and the main part of the rotor would be loose behind it. I was surprised to find that the rotor was actually rusted (bad) to the edge of the hub and the face of the rotor slipped right off. It still took a little work to get the old rotors off the hub.
Lesson learned: change the rotors more often, or at least pull them off and apply anti-cease to the edge of the hub.
  #2 (permalink)
Old 06-25-2008, 06:15 PM
Pejeeper Pejeeper is offline
Pejeeper is starting off with a positive reputation.
A tank of map gas, a large sledge, and a few beers...curse words help too.
  #3 (permalink)
Old 06-29-2008, 02:45 AM
JJ98 JJ98 is offline
1998 Ford F-150
JJ98 is starting off with a positive reputation.
ive changed rotors on some other cars and truck i just put sume wd40 on it for a 1 and use my 10 pounder on the hit and rotat and they just pop off
  #4 (permalink)
Old 07-02-2008, 10:35 PM
bmuhlbach bmuhlbach is offline
bmuhlbach is starting off with a positive reputation.
I had to do some thing on my kids 2001 cut about 1/3 of it off between hub and 2 lug studs.
  #5 (permalink)
Old 06-09-2009, 05:53 PM
LOOnatic LOOnatic is offline
LOOnatic is starting off with a positive reputation.
I went through the dreaded "stuck rotor" issue doing a brake job on the wifes escape this weekend. I read all the threads with guys cutting and pounding the bejeses out of them.
*Here is what worked for me*
Loosen the lug nuts to finger tight and then back up in the driveway about 5 feet slowly and stab the brake pedal. Drive forward a few feet and hit the brake pedal.
The stuck rotor moaned loose from its crusted state and thus, a long battle was avoided.
__________________
04 F-250 6.0
List Mod's In Gallery
FTE
  #6 (permalink)
Old 06-09-2009, 06:22 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
If I get a stubborn one sometimes I spray the area with penetrating spray,and that usually helps too.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
  #7 (permalink)
Old 06-10-2009, 10:19 AM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
I guess I got lucky, my '05 had 87K on it and original brakes when I did mine last week. I just beat on the rotors on the outer edge with a 2lb hammer and they eventually broke loose. The rear drums were stuck, too, but also succumbed to the big hammer method. I put Permatex Anti-Seize on the inside of the rotors and drums going back.
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #8 (permalink)
Old 06-17-2009, 12:17 PM
Redranger03 Redranger03 is offline
Redranger03 is starting off with a positive reputation.
Anyone know off hand what size allen wrench is needed to remove the caliper bolts on the Escape? Mine is a 2009.
  #9 (permalink)
Old 06-17-2009, 01:10 PM
wptski wptski is offline
wptski is starting off with a positive reputation.
Quote:
Even the '09 shop manual doesn't list the wrench size just the torque for tightening.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #10 (permalink)
Old 06-17-2009, 01:26 PM
Great, I have metric & standard, neither fit!
I want to slather some never seize on the rotors/hubs to hopfully make it easier to remove when pads need changing.
Maybe some one knows and will reply.
  #11 (permalink)
Old 06-17-2009, 01:36 PM
I seen that questioned asked elsewhere but maybe not for a '09. I think that it's Metric. What's it close to and what size is inbetween? It's 37ft/lbs if you care to know.
__________________
Bill
  #12 (permalink)
Old 06-18-2009, 10:03 AM
3/8" is too big and 8mm is too small. I am guessing 9mm but sure enough, my set does not have that size...(communist metric!) I will pick up a 9 & 10 mm next time I'm out & about.
Thanks for the torque info.
  #13 (permalink)
Old 06-18-2009, 10:12 AM
From my memory of the post elsewhere, I was going to say it's a 9mm too!
__________________
Bill
  #14 (permalink)
Old 06-28-2009, 11:44 AM
boatswine boatswine is offline
boatswine is starting off with a positive reputation.
Even though it looks like an allen a T45 worked like a champ on mine. However, even with the bolts and clips removed, I can't get the calipers to slide off. Am I missing something?
  #15 (permalink)
Old 06-28-2009, 10:16 PM
try to push the piston in on calaper and pry up on one side then the other its been a while sense i did mine but thats what i remember doing.i believe its holding up on the inner brake pad.
__________________
Buy American your job depends on it.
Tags
f150 , rotor , stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
