Archived Oklahoma Buy/Sell/Trade Ads - Page 2 - Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
Closed Thread
Old 02-22-2005, 11:39 AM
OKLAHOMAF100 OKLAHOMAF100 is offline
OKLAHOMAF100 is starting off with a positive reputation.
I have a toolbox on the back of my 71 F100. The regular type, running all the way across the bed up against the cab, opens on each end. It appears to be very old, and is definately not waterproof, but I think the price is right (free). If anyone wants it, E-mail me. I'm in Broken Arrow.
Brandon
PLAYRR2000 at YAHOO.COM
Old 02-23-2005, 03:36 PM
rogerf100's Avatar
rogerf100 rogerf100 is offline
rogerf100 is starting off with a positive reputation.
Headlight 1994 F150
I need a left (driver side) headlight for my 1994 F150. The bulb came loose and melted the plastic socket of the reflector.
Old 02-25-2005, 10:21 PM
Lobuck76's Avatar
Lobuck76 Lobuck76 is offline
Lobuck76 is starting off with a positive reputation.
Quote: I need to buy an engine stand large enough for a fully built 390. I am thinking one of those 1000# units with the 4 wheels and all that, for stability. I will be leaving it out (I don't have a garage) in the weather under a cover. thanks y'all, lemme know!!Quote:
I had one of the import 1000# motor stands, I wasn't real confident with a small block hangin on. I bought a 2000# stand at o'reilly's for 119$ I think harbor fright has one just like it for about 100$ I had a fully dressed 360 on it with no worries
Old 02-26-2005, 01:31 PM
rogerf100's Avatar
Quote:
Another good place to look is Steve's Wholesale Tools on Santa Fe just south of WalMart. Also keep an eye out for a tool sale at the Cleveland County fairgrounds in Norman. They put out a sale flyer in the newspaper the week of the sale. Get there early on the first day because many items ell out. That is where I bought my engine hoist and a few tools. Got a good deal on a rubber floor mat for my work bench. Makes it easy on the feet when you spend a lot of time at the bench.
Old 02-26-2005, 04:07 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
Quote:
Originally Posted by SwOkcOffRoader
I am now in the market for an older compact truck, i would prefer a toyota, but all the riceburners(nissan,mazda etc..) are about the same!!! Im specifically looking for a Toyota 4x4 X-cab with a manual tranny and A/C in decent shape....I need this for a daily driver to save on gas so i can put the money saved in to my Fords ...Im looking for one in the $1500-$2000 range give or take........
update: i found an 87 pathfinder 4x4, so im no longer searching....thanx...
Old 02-27-2005, 02:58 AM
Arnold Kenyon Arnold Kenyon is offline
Arnold Kenyon is starting off with a positive reputation.
I need the passenger headlight bucket for a 1979 F-150 square headlight.
Old 02-28-2005, 12:37 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Wanted: Front Upper A-Arms for mustang II suspension.(1974-78 models)
Old 02-28-2005, 11:43 PM
PowerbyFord PowerbyFord is offline
PowerbyFord is starting off with a positive reputation.
Parts in Midwest City
Sorry about this, I listed this as a regular thread without reading here first. I have some 78/79 parts for sale, and an auction on ebay for two complete frontends. #7958245656 I have a bunch of parts, give me a shout and I may have what you are looking for....Sorry again about the other post. I need to read first next time
Old 03-01-2005, 02:29 PM
rogerf100's Avatar
Quote:
Found a new headlight housing on epay for about 1/3 the cost of dealer part. Hope it is good quality plastic.
Old 03-03-2005, 02:59 PM
rogerf100's Avatar
I was in Harbor Freight today and they have a heavy duty engine stand rated at 2000 lbs for $79.99 marked down from $99.99. The store has moved to the corner of Reno and McArthur in OKC.
Old 03-03-2005, 06:17 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
I've got some stuff I want to sell. I really don't want to trade for anything but money, but I'll entertain the possibility. Most of these parts are in Stillwater in my Dad's shop, I am in Tulsa. Here goes:
9" rear end out of 76 Thunderbird. Open diff. spline count and gear ratio unknown. The housing on this thing is the largest 9" housing I've ever seen, so possibly 31 spline. $150
8" rear end out of 67 Cougar. 3.00 ratio, open diff. Possibly have more than one, don't remember. $100
3 C6 transmissions for 429/460. All need rebuilt. One has a chunk out of the bellhousing on the bottom, not a structural issue. All have tailshaft for slip yoke driveshaft. $50 each or all three for $125
1 C6 transmission for FE engine. Needs rebuilt. Tailshaft for slip yoke. $75
1 3spd floor shift HD trans for flathead engine. This is a whole setup including flywheel, clutch disc and pressure plate. Pulled from 48-52 F-1, not certain of exact year. It's a long story, but this trans only has a few hundred miles on it since new. $250
Stock 429/460 iron 4 barrel intake manifolds. I think there are 3 of them. $20 each, $50 for all, or will go with BBF stuff below when it sells.
429/460 parts. I've got 2 or 3 blocks, 2 or 3 429 cranks, a few sets of rods, tins, timing covers, brackets, bolts, etc. A very good size truck load of big block stuff. Some is in perfect condition, some is junk. I don't have time to go through it all and see. There are enough parts to build one complete shortblock and maybe a second. Take it ALL for $250.
Dual snorkel air cleaner assembly for 82-85 Mustang 5.0 HO. Needs cleaned and painted. Good condition. $50
Ford 302 engine. Disassembled, but complete AFAIK. Came out of 77 Mercury Monarch and was running. I swapped a 351W in for the guy and still have the old engine. $100.
Iron 2 barrel intake for FE. $10
Take everything in this add for $1000 and I might throw in some other stuff that I am forgetting about as well.
Old 03-03-2005, 07:38 PM
Traxxis's Avatar
Traxxis Traxxis is offline
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
Quote:
Originally Posted by Traxxis
Okay everybody... uh... bad news. Just found out the Chapters are now only allowed to have "wanted" ads, instead of "for sale" ads.
I think those of you who have already posted "for sale" (including myself) are okay... nothing we can do now. But for now on, we have to keep replies to wanted only.
Sorry
STan
Hehehe.... Sorry Silver Streak. No more for sale ads. You can post them in the classified section and post a link in this forum... but I didn't tell you that.
STan
  #28
Old 03-04-2005, 12:42 PM
Sorry, didn't see that post. Where exactly is the classified section? I've looked up and down the forums and don't see one anywhere.
  #29
Old 03-04-2005, 12:46 PM
okacookie's Avatar
okacookie okacookie is offline
okacookie is starting off with a positive reputation.
wanted: a bench seat that will fit in a 94 bronco... i have buckets and my drivers side seat frame snapped so it is my excuse to get a bench. it needs to be a split bench and hopefully in good shape... if you want i may even be willing to trade my buckets for it. thanks.
chris
  #30
Old 03-11-2005, 10:16 AM
76Forder 76Forder is offline
76Forder is starting off with a positive reputation.
OK, i need a right front fender and right front headlight frame for a 93 F150 red and white in color would be ideal but if its dent free itll work all the same. im in vinita send a pm to me with prices and availability, lol
Closed Thread
Obsolete/Classic Ford in Oklahoma City 76-5.0 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 02-08-2016 01:32 AM
AC shop MikeB 88 Oklahoma Chapter 16 12-09-2015 08:58 AM
New member here from N Carolina WrightNow New Member Introductions 0 03-27-2015 04:01 PM
Wanna Share Your Local Restaurant Reviews?.... cigarxtc Oklahoma Chapter 106 12-30-2014 09:23 AM
Where to Get Real Gasoline in Owasso?..... cigarxtc Oklahoma Chapter 14 02-05-2010 07:40 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
4562482, 74, 907, 93, b700, bus, end, enid, f150, ford, gvw, lifted, nice, oklahoma, rear, specs, trade, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
