Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 6.2L Boss
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.2L Boss Discuss the upcoming 6.2L V8
Is F-150 Still King?
  #31 (permalink)
Old 08-20-2008, 11:37 AM
Ace!'s Avatar
Ace! Ace! is offline
Ace! is gaining momentum as a positive member of FTE. Ace! is gaining momentum as a positive member of FTE.
What, jet engines in a Ford? Now I'm confused.
__________________
2005 F250 V10, CC, SB, 4x4, 4.30 axle ratio
1994 Exploder XLT, 4x4, auto trans and Pioneer cd player
"Deserve's got nothing to do with it"
  #32 (permalink)
Old 08-20-2008, 12:24 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Quote:
You just had to start, didn't you?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #33 (permalink)
Old 08-20-2008, 07:21 PM
meanv10's Avatar
meanv10 meanv10 is offline
meanv10 is starting off with a positive reputation.
just got my 4wheeler mag and they had a right up that said that ford was likely going to cancel the boss motor in the F150 and along with it, the F150 raptor, because it was supposed to have that motor so that program is currently "under review"
they did say that it could ind its way into the superduty though.
Bottom line is Ford better figure a way for these motor to make more ponies, or the competition is going to keep pulling away.
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #34 (permalink)
Old 08-21-2008, 02:47 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
I just think theres quite a bit of power to be had with the modulars without going into a forced induction or more displacement. A 4V 5.4l, modified cam profile and some other tweaks would put out good power with little retooling. Maybe even a ci bump with a stroker crank. A 400+lb weight reduction would help, I'd start cutting fat out of the interior and cutting the bed rail height and window height down to normal on the F-150. At this point with the truck market slump I just don't see a need to replace modular truck motors, just refine to keep up with the competition.
  #35 (permalink)
Old 08-21-2008, 05:43 PM
Krewat's Avatar
I wonder how much that would effect emissions? And what does it cost for Ford to certify the engine for Federal AND California/Green-state emissions?
__________________
  #36 (permalink)
Old 08-21-2008, 05:45 PM
Ace!'s Avatar
Quote:
I hadn't posted in a while and figured I start out with some BS!
__________________
  #37 (permalink)
Old 09-01-2008, 02:07 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
4.17" stroke isn't long enough?? The small bore shrouds the valves limiting power without a power adder.
This is why these engines respond so well to forced induction. ( supercharger or turbocharger).
The Navigators had a 4V 5.4L and only had 300hp and about the same amount of torque.
The 3V engine outperforms the naturally aspirated 4V engine.
2001 Cobra 4.6L 32V had about 320hp?
2008 Bullitt Mustang 4.6L 3V has 315HP and better low end torque.
I don't think a 4V head is the answer at this point.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #38 (permalink)
Old 09-01-2008, 02:28 AM
LxMan1's Avatar
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #39 (permalink)
Old 09-05-2008, 11:14 PM
obey_your_master obey_your_master is offline
obey_your_master is starting off with a positive reputation.
Hey why not, chrysler tried it out in the sixties and seventies.
Chrysler Turbine Car - Wikipedia, the free encyclopedia
....now put hydrogen in the equation.....
  #40 (permalink)
Old 09-07-2008, 02:51 PM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
a diesel in a half ton is dumb to me......if you want a diesel .....get a heavy duty truck. just man up and drive a bigger rig.
  #41 (permalink)
Old 09-16-2008, 12:18 AM
2000BLK54 2000BLK54 is offline
2000BLK54 is starting off with a positive reputation.
We're arguing the same point.
The temp drop across the exhaust side of the turbo is a by-product of the expansion of the exhaust gas. You're not harnessing the heat to produce energy. Quite the contrary.
Conservation of energy. No Such Thing As A Free Lunch.
Anyway...
Need to brush up on your Thermodynamics. HEAT is precisely why turbochargers work as well as they do. The energy of the HOT, EXPANDING exhaust gasses are exactly what is imparting energy to the turbine. The temp drop is not a by-product of expanding gas, the temp drop is a direct relation of work/energy transfer from the exhaust gas and the more heat involved the better the transfer takes place. You are right that turbos are not a free poweradder....but heat is the majority contributor here. It all goes back into why turbochargers are load sensing...load being the fundamental term here.
Oh, and for Ford going to a big block...GM already tried that approach, didn't work very well then and it sure as hell won't work well now.
__________________
2000 F-150
SuperCab 5.4L, Flareside
S&B, Flowmaster SI/DO, T. Perfomance Dual Electric Fan Kit, ATI ProCharger P-1SC (12 psi), Snow Methanol injection, Jet-Hot full length headers, offroad exhaust
www.cardomain.com/id/2000blk54
  #42 (permalink)
Old 09-16-2008, 08:54 AM
meanv10's Avatar
Hey your wright, im going to go run the EGT's up to 1800 degrees and see how awesome my turbo works! lol
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #43 (permalink)
Old 09-16-2008, 01:35 PM
Krewat's Avatar
I'm still not buyin' it. The exhaust has already expanded as far as it will go, in the cylinder. The gases moving out the exhaust port of the head, pushing against the turbine is what is moving the turbo.
The gases are no longer expanding after they have left the cylinder. If anything, they are cooling off, contracting. Combustion has finished once it has left the cylinder. There is no heat being added after combustion is done.
Granted, there is a temperature rise, as the gases are compressed by having to do work by pushing the turbine. A bigger the intake turbine on the turbo, the more the exhaust gases are compressed before the exhaust turbine.
It basically hydraulics with gases instead of a liquid. There is no magic "expanding of exhaust gases" after it leaves the combustion chamber. If anything, it is being compressed even more (raising the temp) before the exhaust turbine.
__________________
  #44 (permalink)
Old 09-16-2008, 09:49 PM
And you'd be wrong. Think about it, rich air-fuel mixture + retarded ignition timing = stuff is STILL burning even as the exhaust valve is opening. Those in hi-po turbo drag cars take this effect to the extreme, called an anti-lag setup. Look it up.
Turbochargers, like all gas turbine systems, are fundamentally heat engines. Heat engines...why do they call them that you think?
And for the quip from the guy about running the EGT's up to 1800 degrees: if the turbine could handle that kind of temperature for a given period of time the turbo WOULD work better. The most advances in gas turbine technology has been in coming up with materials that can withstand higher temperatures. Engineers know this, you'd do well to understand as well.
For the sake of further argument I'm just going to post a quote from one of the best turbo resources on the net.
Quote:
The turbine is powered by hot expanding exhaust gas, a lot of hot expanding exhaust gas, the more and the hotter the expanding exhaust gas the better. I am sure many of you have seen pictures of turbo charged engines with cherry red hot exhaust systems and turbo housings. The captions under most of these types of pictures proclaim outstanding horse power numbers. What most of the articles related to these pictures do not tell you is that the engine was under an extreme load. A load so heavy that the engine was almost at its stall point for a prolonged period of time. A condition that most turbo charged engines will never see.
Some of you should do yourselves a favor and read the ENTIRE article a few times...
http://www.turbomustangs.com/turbote...charger_theory
__________________
2000 F-150
  #45 (permalink)
Old 09-16-2008, 10:53 PM
Krewat's Avatar
And you'd be wrong.
It wouldn't be the first time
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
