2002 SD Stuck In Park
I am hoping this is just a switch somewhere that I can swap out, but here goes. Drove the truck to my sons little league game, put it in park, hopped out, coached the game, when we went to leave I cranked (Crunk?) it up, went to put it in reverse, and it wouldn't budge out of park.
So I removed the lower dash piece to look for something/anything out of place, or unhooked, nothing. So I cut the truck off, turned the ignition just a little bit towards on, pulled the shifter into nuetral and crunk it up and drove home.
Has anyone else had this happen? I havent had any issues out of the truck and it is just over 70k miles.
Any help would be much appreciated (pictures too!).....
The brake lights work. I found the fuse, it is no.31, the first one on it's side. I replaced it with a new 10amp fuse and as soon as it was seated it blew. I put an electric brake controller in a couple of months ago (using the factory harness and all) so I pulled that out, thinking that maybe that was the issue, but when I put a new fuse in again it popped.
Where is the brake switch? I am guessing it is under the dash somewhere, but it would be nice to see it to get an idea.
on the bottom of the steering column is the shift interlock solinoid.If you unplug the soliniod ,it disables the solinoid and the shifter will work without your foot on the brake. They made it this way because if the battery is dead and the truck needs to be towed , there has to be a way of putting it in nuetral.
Tell that to GM. The Grand Prix I have you can't even take the key out without battery power.
The brake lights work, and I have had pretty good luck getting it into Neutral to start it, just turn the key forward a little and it will click right on down. Hopefully I will have more time this weekend to get further into it. I wish someone could post a diagram from a service manual, that would be much appreciated. (I will take pictures once I figure it out)
Starting around 1999, Ford changed the circuit so that the brake light circuit no longer is used directly to release the shift interlock.
The procedure to turn the ignition switch forward, then shifting into neutral to start is in your owner's manual. That's the prescribed work-around of an interlock failure.
I would suspect the BPP switch first, it is likely shorted internally.
Steve
Steve
What exactly does BPP stand for?
