halfwaterhalfgas
Water and gas do NOT mix. They have different specific gravity values. I have a Yamaha 225HP V Max HPDI that protects itself from water in the gas. Water is heavier than gas so if you get water in the gas the gas floats on the water. In the final filter for my outboard there is a float that floats only on water, but not on gas. If you get some water in your gas the float will rise and set off an alarm and shut down the engine until you flush out the water. The last time I checked firemen use water to put out fires not start them.
Oxyhydrogen - Wikipedia, the free encyclopedia
Oxyhydrogen is often mentioned in conjunction with devices that claim to increase automotive engine efficiency.
Many of these claims, prima facie, violate the Law of conservation of energy. See Conservation of energy and Electrolysis of water:Efficiency. To date, none of these claims have been proven, and most have been fraudulent.
A wise philosophy considering that this concept is already in play!
Scorpion sportscar would burn gasoline and hydrogen | Green Tech - CNET News.com
I haven't read exactly how the system works, but I assume it injects the hydrogen at some point downstream of the throttle body, which would be exactly the same effect as a throttle-body injected, or carburetored system works. They all have an explosive mixture of fuel/air downstream of the throttle plates that is distributed to the cylinders via the intake manifold. I can't recall too many cases of people getting blown up using those systems...
