2005 Ford Explorer XLT Service Engine Soon
I searched the forum and didn't see reference to this problem so forgive me if I missed it and am duplicating here...
I have a 2005 Ford Explorer XLT AWD with a V6 (59,500 miles). I pull a boat all summer. It has never given me a problem. Last weekend, I filled up at a Marathon station and my "Service Engine Soon" light came on. I checked my gas cap, checked my book and thought maybe I got bad gasoline so I ran that tank out and filled up at a station I have always used... the light is still on.
Is this common? Could this be serious? Is there anything I can check and/or do myself before taking it to the dealer? Is there a way to get the code for the problem?
Any help or advice you can give will be greatly appreciated!
fyi...the light merely means one of the subsystems of the vehicle is out of parameter. Virtually everybody is in agreement that as long as the vehicle is still operating nicely and the fuel economy hasn't tanked, ignore it. Sometimes the computer will make an adjustment to the way it operates because of the sensor's message. Now the vehicle may be using excess fuel because a course correction was made when none is really needed.
When filling up at any gas station, shut the car off.
The fuel/ evap system is typically a sealed system when the truck is running. When you are re-fueling, the "seal" is broken and over a period of time this can set the CEL light or service engine soon light.
Of course, gas caps can fail.......
