ACCEL Coil Packs
ACCEL Coil Packs
Has anyone used these? I've got to replace all my coil packs and was looking at these, $200 for a set of eight, includes boots and springs. One thing I like about them is they tell all the specs. on them. The only ones I've seen with that. Also does anyone make rubber boots to go over them, has anyone extended their splash shields behind the front tires? If so, what did you use?
I bought the ACCELS, P/n 140032. (for 4.6L / 5.4L / 6.8L 2 valve Modular) they came with the boots and springs already attached and dielectric grease on them. Put Dielectric grease on the outside of the boot where it contacts the opening to the plug. Ohmed all of them out, for later reference. Engine runs great. They are Yellow, which makes them easy to see. PS for 4.6L / 5.4L 6.8L Modular 4- Valve the P/n is 140034
miko6810
05-06-2014 09:18 PM
