1995 Explorer Premium Sound System, Wiring Diagram, Amp Location?? Help - Ford Truck Enthusiasts Forums
Old 03-22-2001, 02:46 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I am trying to add a amp to the stock system if a 1995 E.B. Explorer. Does anyone know where the amp is located? Also, I want to tap into the low level signal before it reaches the amp so I can run that to my add on amp. Does anyone know where to get a wiring diagram for the system? Thanks in advance.
Old 08-27-2001, 11:47 AM
KNELSON3 KNELSON3 is offline
KNELSON3 is starting off with a positive reputation.
I was wondering if you found any information on this problem. I am installing two twelve in subs and I am not getting any bass output out of my subs and I need some help with it.
Old 08-30-2001, 11:42 PM
borland borland is offline
borland is starting off with a positive reputation.
The factory amp is in the right rear quarter panel in the luggage area. Easy to remove, some screws, bolts, etc.
I Just replaced the factory amp on my 95' Explorer. Used a 200 watt, 4 channel amp (AudioVox Rampage). This is a great amp. I got it at Pep Boys for $50 plus tax.
Recommend you replace the factory speakers as I did. I don't think the factory units can handle the extra power, bass, and treble that the new amp puts out. I'm really impressed with the new sounds.
You also need to purchase a ground isolator/level converter. The factory radio drives the factory amp at speaker levels, so you need a level converter for the amp low level inputs. Also, the low level inputs are usually common ground which won't work with your factory radio, thus the ground isolation is required. I bought mine at Radio shack has these for $15 each, you need two, but later saw a 4 channel unit at Kragen for $20.
good luck, borland
Old 09-02-2001, 02:23 PM
edszhi edszhi is offline
edszhi is starting off with a positive reputation.
Does anyone know where the amp is on the 91 4door LXT?
Thanks
Ed
Old 09-04-2001, 11:17 AM
buzz1973 buzz1973 is offline
buzz1973 is starting off with a positive reputation.
Same place. Rear passenger quarter panel under the plastic.
Old 09-05-2001, 07:11 PM
cotoole cotoole is offline
cotoole is starting off with a positive reputation.
Old 02-28-2014, 03:13 PM
bsmustang98 bsmustang98 is offline
bsmustang98 is starting off with a positive reputation.
Red face Fuses are good but no power to Radio
I have done everything possible. Stereo worked, turned car of for 5 mins and nothing. Again all fuses possible have been replaced. Please someone help!!!!
I just want to add a subwoofer . . . SCREW 6.7L Power Stroke Diesel 4 10-13-2015 01:16 PM
1995 E350 No Power jsikora 1968-2013 Full Size Vans 5 05-28-2015 06:55 PM
Power Doorlocks 87&97Aerostrar Aerostar 5 03-13-2015 01:58 PM
2001 Expy - Does it have a AMP for the door speakers???? Araltd 1997-2006 Expedition & Navigator 2 01-06-2011 10:29 PM
Can you add a factory sub where none was? tapper95 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 09-02-2004 02:16 AM
Tags
1995, 94, amp, amplifier, club, diagram, explorer, ford, location, premium, radio, sound, stock, system, wagon, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
