Dana 44 questions
Dana 44 questions
When i was pushing the old u-joint out of the passanger side axle shaft, the press ended up bending the piece in the picture to where i cant get the new u-joint in. Could i use the driverside shaft untill i can get to the wrecking yard and get a new one?
Second, how do i remove the shaft coming out of the differential so i can clean and replace u-joint and seals?
Thanks
JM
Thanks
JM
I would just use the press to bend the yolk back open so you can put the u-joint in.
As for removing the passenger axle shaft, there is a "C" clip inside the carrier that goes on the end of the axle shaft. Look inside the spider gear on that side. You need to pop that off then the axle will come out
I went out with a hammer and it took me 2 minutes and it came out nice and everything was intact. The bearing also looks brand new! The cool part is is i got the truck for $100 bucks, the front brakes were all brand new, the bearings looked to be brand new as well! And NO RUST!!! lol It makes me happy when i find things like that!
Another thing. The axle shaft in the second picture, I got that out, but now i cant get the bearing retaining ring off the end so i can replace what needs to be replaced. I read that you have to break it off of there but i dont want to do that until i know i can get a new one... Long story short, where can i get that retaining ring?
1980 Ford F-250
11-12-2013 11:50 AM
1980 Ford F-250
121
06-22-2013 03:22 AM
1980 Ford F-250
10-07-2012 09:35 AM
1980 Ford F-250
05-23-2011 08:13 AM
