Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-21-2008, 07:33 PM
renoduckman is starting off with a positive reputation.
tie rod removel
I need to replace the tie rod ends on my 87 Ranger. I rented a removel tool and it pops the tie rod end out very easy. But where im having trouble is unscrewing the old tie rod end from the clamp. I have loosend the bolt on the one side to unscrew it and its moving but a slow fight to get it out. Am i missing someting on this? Is that normal? I didnt want to loosen both bolts on the clamp? Any thought or advice. Thanks joe
__________________
2002 F250 7.3 4x4 long bed super cab 6 speed
1987 Ranger 2.3 4x4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-21-2008, 07:51 PM
Rangerman Stan is starting off with a positive reputation.
If the bolt is still tight on the other end of the clamp it will make it difficult to remove the tie rod because it is still clamping down on the rod end. It will take some work to get it removed too because of rust that's in the clamp with the tie rod. So, what you're experiencing is normal. You could spray some lube in there to make it come out easier. Like WD40.
__________________
1991 Ranger XLT SC 4.0 A4LD 2wd 180,000 plus
1990 Ranger XLT SC 2.9 5spd 2wd 229,000 plus
  #3 (permalink)
Old 06-21-2008, 11:28 PM
tie rod
Yes i have got one but its a fight. And i did try wd40 also. So do you think i should loosen the bolt on the other side of the clamp? I have to wait for a part i orderd before i can work on the inner tie rod. Also when i do the inner tie rod does it make sense to remove the whole thing in one piece so i can put in a vise and replace both ends? Thanks joe
__________________
1987 Ranger 2.3 4x4
  #4 (permalink)
Old 06-22-2008, 01:57 PM
Yes you could loosen the other end of the clamp to help it come apart easier. Holding the other parts in a vise when you take them apart will make it go easier for those too. Just make sure you get an alignment after you're done. You don't want your truck to eat up tires after all that work was done.
__________________
  #5 (permalink)
Old 06-22-2008, 04:51 PM
tie rods
Thanks Stan, i appreciate the input. I have had a pair of Rangers and they have both been good trucks. But i have been do for an alignment so its no big deal. I guess i want to get it close so its not so far off when i take it to an alignment shop. Thanks and i will keep you updated. Joe
__________________
1987 Ranger 2.3 4x4
  #6 (permalink)
Old 06-22-2008, 06:40 PM
customstringer's Avatar
customstringer is starting off with a positive reputation.
Don't know if it will make a difference but there are some other penetrating products to try to see if will help loosen things, PB Blaster, Kroil [not in stores] CRC freeze off, your parts store may have one or more of these, probably PB Blaster for sure. Good luck.
__________________
97 Ranger XLT flareside 2wd 2.3 M5OD, stock everything and no a/c. Built Ford Basic.
  #7 (permalink)
Old 06-23-2008, 08:07 PM
tie rods
Well i got it almost done. Funny how a project can go. What i thought whould be the hard part of the job, getting the tie rods to pop out was easy with the tool i rented. But getting the toe rod out of the clamp was tough. Im going to take the other side to work so i can use a vise to hold. Then should be ok and time for an alignment.
__________________
1987 Ranger 2.3 4x4
  #8 (permalink)
Old 06-25-2008, 01:33 AM
tie rods
Well got it all done today. Not too bad. Got to get in for an alignement. No mattter how i tryed it was imposible to keep the tow in correct.
__________________
1987 Ranger 2.3 4x4
  #9 (permalink)
Old 06-25-2008, 02:17 PM
wtroger is starting off with a positive reputation.
Setting the tow in is the easiset thing you can do all it takes is a tape measure.Use a natural line in the tread pattern on the front tires. measure the front side of the front tires then measure the back side of the front tires from the same reference point then note the difference. the fronts' should be about 1/8 inch narrower then the backside. (reference shop manual for exact measurement). then turn the adjuster sleeve in or out until you get the toe in correct. In order to keep the steering wheel straight you may need to adjust both sleeves on each tie rod end.
  #10 (permalink)
Old 06-26-2008, 01:47 AM
Pablo-UA is starting off with a positive reputation.
It sounds funny, but if WD-40 does not help, try Coca-Cola! it is strange, but works!
  #11 (permalink)
Old 06-28-2008, 08:09 PM
tie rods
Well i got it all done and had an alignment. Came out good and seems to drive well. I repalced 3 tierod ends, the long stereing link was ok as it was replaced before. Got by for only 87$ in parts and 53$ for the alignment, that i needed any way. Saved alot of money by doing it at home. Joe
__________________
1987 Ranger 2.3 4x4
  #12 (permalink)
Old 06-29-2008, 12:25 PM
I fortunatly have an access to Truck aligner-II on my work and do aligment myself. not so easy work as it seems from first sight, especially on big buses with intependent suspention
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
