Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-22-2008, 09:12 PM
flcracker9 is starting off with a positive reputation.
No you don't need to remove the hubs. Just the tire and wheel assembly, and there should be 3 large slotted screws that attach the drum to the hub assembly (if someone hasn't already discarded them). If you have the money, I would replace everything. Brake linings, drums, wheel cylinders master cylinder and the power booster. I replaced all of these, and it cost me around $400, but since I did this my truck stops on a dime with very little pedal pressure, even with 39.5 tires. I can lock them up very easily if I need to. I was actually going to swap front ends so I could have power discs, but I see absolutely no reason to do that now, I couldn't be happier with my drum brakes. My 74 is not a daily driver, so longevity with the front shoes is not really an issue.
__________________
74 F250 High Boy, 300ci, Demon 525, EFI maifolds, 260H Cam, 39.5 Swampers
86 F150 4X4, 351, GT40P Heads, 274 Cam, Crane roller rockers, Mac Headers, Demon 725, 35" pro comp muds
03 F250 Super Duty 7.3 Diesel, K&N Intake, Edge W/Attitude programmer, 4" exhaust, 35" Mickey Thompsons
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 06-23-2008, 05:34 PM
jackndelphine is starting off with a positive reputation.
Well thank you for the info, I am glad to hear that I don't have to remove the hubs, less work is better at this point in my project. Anyway, I was planning on replacing everything because this truck sat for a real long time and I am not going to trust these old brakes to stop the truck when my daughter is in it with me and other peoples lives are at stake, there are a lot of things you can skimp on but I don't think brakes are one of them. I am gonna go outside in a little bit and see if I can shove that vacuum line directly in the booster, without the check valve on it, just so I am sure I am not replacing the booster when it was the 8 dollar chack valve the whole time, lol. I will post what I find later on. Oh, and any recomendations on where to get a complete brake kit for my truck for a good price?? -----Jack
  #18 (permalink)
Old 06-24-2008, 07:54 PM
So here is the update, I went outside last night and tried sticking the vacuum line directly into the booster without the check valve on and it didnt work, so while the truck was running I put my finger over the end of the line and it had vacuum but not a lot, so then with the truck running I took the line off the manifold and then the idle got crappy and I heard it sucking away like crazy, so then I looked inside the line and it was almost completly clogged, so I blew it out with air and it cleared up and I put everything back together and whammo! I had awesome brakes, the pedal is still a little low but I am planning on changing most of the brake parts anyway so I should be able to solve that. The only thing I did notice is that when I press on the brakes I hear a loud huff!! Come from under the dash, obviously from the booster, but is that normal, or is the booster on its way out? Anyway, I was happy to get my brakes working and was able to take the truck out on its maiden voyage around the block, its the first time I drove it since it limped its way in my driveway and I had to change the engine, cab and front clip. The truck ran absolutly terrific, it actually felt like a real truck. Anyway, that all for now, and thanks for all the help everyone. Jack
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
