i have a 97' f-250 with a 2 piece drive shaft and in the center where it is rubber mounted is starting to wear and causing vibrations. is there any reason a cant put a one piece drive shaft under the truck
They use a 2 piece shaft to keep ground clearance. Midship bearings are cheap compared to a custom made 1 piece drive shaft.
