Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2008, 06:56 PM
esucarys esucarys is offline
esucarys is starting off with a positive reputation.
Ignition problems?
For whatever reason I could not get my truck to shut off the other day. The ignition switch turned normally to the right and left but didn't seem to "click" into any positions. I had to eventually drive it home and switch over to the alternate gas tank (that was empty) to get it to shut off. Without thinking I forgot to disconnect the battery and it died overnight. I took it to get it recharged and ended up having to buy a new battery. So, knowing the battery is brand new, when I pulled the steering wheel and installed the new ignition switch I was surprised to find that the same problem still exists. The car will not turn on or turn into the off position. I had to disconnect the battery and throw my hands in the air. What could be the problem? I would normally assume it's the starter, but it won't shut off either. It seems like the ignition (brand new) is just not turning whatever it is inside the steering column that clicks it into place.
  #2 (permalink)
Old 06-20-2008, 07:07 PM
trgrhappy trgrhappy is offline
trgrhappy is starting off with a positive reputation.
Sounds to me like either the rod that runs down the column to the actual switch is either broken or has come disconnected from the switch. And I believe, someone please correct me if I'm wrong here, there's another piece that pivots for the tilt columns that has a tendency to break as well. You could try reaching up over the column and see if the rod is off/broken. but that would be my guess. If the lock cylinder turns but isn't working the switch. If the rod's intact you could have a bad switch on the column.
__________________
The Redneck-89 F150 XLT Lariat 302 EFI Auto 4X4
  #3 (permalink)
Old 06-21-2008, 07:51 AM
Lazy K Lazy K is online now
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
Yes it sounds like the ign. switch actuator is faulty. This connects the key switch to the rod that runs down to the ign./start switch. You will find the ign./start switch on top of the steering column under the dash, if you reach up you will feel the rod already mentioned. To replace the ign. switch actuator you will have to pull the steering wheel, the turn signal plate and the column shroud. There are two parts to the actuator but is normally the part connected to the rod that breakes. Cheap to buy but a PITA to fit.
  #4 (permalink)
Old 06-21-2008, 02:14 PM
Thank you guys so much. I am 100% positive that it is the rod. After reading this I went out and checked it out and that seems to be the problem. I really appreciate the advice
  #5 (permalink)
Old 06-22-2008, 10:38 AM
LilDuke's Avatar
LilDuke LilDuke is offline
He rides the short bus.
LilDuke is starting off with a positive reputation.
Easiest way to determine if it's the cam actuator, rod, switch, or key lock is too...
Reach underneath the dash, on the top of the steering column. Twards the steering wheel from where the aluminum bracket bolts up the steering column. Turn the key while feeling the rod. If the rod moves, it's the ignition switch. If not, then it's the actuator cam. To make sure, turn the key to "run" position. Now insert a piece of wire or something about an 1/8th inch into a hole directly under the key switch. Aproximately at the 7 O'clock position if your looking directly at the column from the side. Pull out the key, lock and all Make sure the "tab" isn't broken or worn to the point it's not engaging it's mating hole in the column.
I just happen to be going through this now. If you want, I'll take some pics.
__________________
Dave
'93 Ranger XLT 4.0, 4x4, 179,000 and counting. (For Sale)
'92 F-150 XL I6, M5OD, 4x4, 186,000 and counting. (For Sale)
'90 F-250 XLT 7.3 IDI, E4OD, 181,000 and counting.
'95 Explorer XLT 4L, 4R55E, 4x4. 156,000
Hiding in my own little corner of the world!
  #6 (permalink)
Old 06-22-2008, 03:46 PM
Pictures would be great. I replaced the ignition switch already, so I'm pretty sure it's the rod.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
