Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-20-2008, 03:19 PM
wilkinsonk86 is starting off with a positive reputation.
Help! Fuel leak in engine
Ok, It's an 86 F-250, 5.8L. Been smelling gas from the engine compartment, noticed something dripping while idling, backed truck up, checked, it's gas. I don't even know where to start looking, bad carb, bad fuel line, etc. Any ideas would be helpful. I'm hoping this weekend to start checking it out, see what i can figure out.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-20-2008, 04:10 PM
jason85351's Avatar
jason85351 is starting off with a positive reputation.
Probly a bad line between the pump and the carb check it for cracks.
__________________
1985 Ford F150 351w 4x4 lift 35" BFG Mud Terrains
Finally Finished driving the truck again till november then putting her in storage
  #3 (permalink)
Old 06-21-2008, 06:08 PM
Iman901's Avatar
Iman901 is starting off with a positive reputation.
The leak is somewhere between the pump and carb, before the pump causes air lock and the engine wont run. I'd replace all the lines with synthetic ones anyway as they say the ethanol in gas now will corrode the rubber.
  #4 (permalink)
Old 06-21-2008, 10:16 PM
ctubutis is starting off with a positive reputation.
Quote:
Originally Posted by Iman901 View Post
...they say the ethanol in gas now will corrode the rubber.
The Colorado Front Range - where I've been living since 1978 - has been burning that
stuff in the Winter months (and some stations have been selling it year-round) for
something around 10 years now. I haven't noticed any corrosion or abnormal deterioration
of my rubber fuel system components, I suspect such scenarios are spread by the fear
mongers who, for whatever reason, aren't willing to accept it.
-chris
colorado, usa
  #5 (permalink)
Old 06-21-2008, 11:37 PM
BTW the Denver/Boulder Metro area has been burning it during the Winter months
since around 1990.
-ct
  #6 (permalink)
Old 06-22-2008, 12:40 PM
80F100man is starting off with a positive reputation.
I would definitely check all fuel lines & replace them even if they look good b4 it starts a fire ! Engine fires are freaky!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
