Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-20-2008, 02:17 PM
compman is starting off with a positive reputation.
Mild 351w performance upgrades
I have been a chevy guy for many years, just dabbling in fords every once in a while. Last year I picked up a really clean low mileage '83 F-150 XLT extended cab with the uber powerful 2bbl 351w (139hp, 278 ft-lbs ), C-6, and 3.55 gears. The engine has about 60K miles on it and runs perfectly, other than it is a slug. I am looking to greatly perk up the 1500-4000 rpm performance on this thing, without spending major $$$'s. It has the evil California emmissions crap on it (EEC-III), with non-adjustable ignition timing and a feedback carb, but no cat (probably removed before I bought it). The carb is a 325cfm holley 80179 (I was told it was designed to replace the evil VV carbs these things came with).
I pretty much figure the EEC-III system will have to go...I plan on replacing the ignition with a 85 series Mallory HEI setup, and I just bought a 80457 holley 600 VS carb. I was going to run a Edelbrock performer 2182 intake but am getting mixed reviews on it. Is the 2182 a worthwhile upgrade? Or even on such a mild setup would a performer rpm or Weiand Stealth be better? The design of the performer doesn't look to good to me...some of those runners make a 135* turn! Would a set of 1 1/2" full length headers be worth the effort? The stock single exhaust will be the first thing to go, but I am undecided how to run the exhaust. The truck has dual gas tanks and running duals conventionally down both sides of the truck won't work...there isn't room. Does anybody have pics of their dual exhaust setups with dual tanks?
I was also thinking of a mild cam upgrade...something like the Erson RV12H or a Comp Cams 260H. Anything else I should consider? I do not plan on removing the heads anytime soon...I can't have it down for that long right now.
I would like to hear about some of you guys/gals similar buildups, and the results.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-20-2008, 09:59 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
With the cam, 4bbl and headers on it you won't recognize the motor, you will have literally uncorked it. I'm not gonna tell you I know a lot about the carb intakes, I have heard the basic Eddy dual plane is a close copy of the stock Ford 4bbl intake... which isn't exceptional. But then the stock heads are small for a 5.8, they won't produce more than about 300hp anyway, so don't get too carried away with the intake, carb or cam.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
