2002 ford escape windshield washer reservoir
...sounds like a junkyard search is in order....
And I'd check with a Ford dealer parts dept--this *may* be a relatively inexpensive part (or not--dunno how they set the pricing on stuff like this).
Good luck,
George
Welcome to FTE. Can I ask why you are replacing it? If the sensor is still good, and you just need to fix a crack, you can buy a fiberglass repair kit (resin & cloth) at wally world, remove the tank, and just apply your fiberglass patch to the tank. I've done this in other applications and it works well.
Semper Fi.
Semper Fi.
F350-6 Oohrah!!
Sorry it took so long to respond to your in put on the washer reservoir problem i have experienced. Having absolutely no luck in locating a used reservoir, nobody seems to want to go to the troubleto remove one, i will repair as you suggested . Thank you and everyone who responded to my problem. I know i will use this forum again . SEMPER-FI, Marine:- DA Cook
JWA
05-06-2021 03:18 AM
LARIAT 85
22
04-06-2015 05:08 PM
BornEdFord
11-26-2014 09:26 AM
rufushusky
Escape & Escape Hybrid
07-22-2011 09:05 AM
SuperSnake
08-11-2008 02:59 PM
