1997 psd idle very low
after my truck is warm if i rev the engine up and let off the throttle it will idle very low for a couple of seconds then go back to a normal idle. its so low it almost stalls, but once it gets back to normall idle speed its fine. also once the engine is hot and i shut it of when i start it back up it ildes very low for a few seconds after it starts, then back to normall. it does not do it when the engine is cold and it runs fine under a load, no other problems at all. just recently i changed the fuel filter, put a new cps on, new ipc sensor. the oil level in the hpop is good and the oil is only 1000 miles old. im thinking either the the injector o-rings or ipr valve or ipr valve o rings. am i on the right track here? any imput would be greatly apreciated
