1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
helper springs
Old 06-19-2008, 11:23 PM
mvcrete's Avatar
mvcrete
mvcrete is offline
helper springs
i just bought a 03' supercab shortbox FX4 5.4 w/ 48k. it sits dead level when empty and all suspension is factory. i hooked my dump trailer to it and the rear sank at least 3.5". the helper springs were not even contacting their pads yet. i know i can install air bags, and if i have to i will, but can i try putting a 2" or 2.5" block under the helper instead of the stock 1".
thanks
Old 06-20-2008, 07:43 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Welcome to FTE!
Yes, the easiest would be to install a set of F-350 blocks and U-bolts. They are 2 inches taller.
Old 06-20-2008, 10:54 AM
aldridgec's Avatar
aldridgec
aldridgec is offline
Sounds like he wants to space the camper spring on top up so it hits the pads sooner.
The camper spring was never intended as an overload spring, it was for stability, kinda to limit the travel on one side if it swayed over to that side. But lots of guys install bigger bump stops on the frame brackets so they hit sooner. It is probably a lot easier than trying to install a block. YOu have to have a block with tabs on the side to keep that spring in line, otherwise it will twist.
Some guys use the energy suspension 9.9101 I think and fill them with polyurethane plastic to stiffen them up some. There is also a (few?) company that sells bump stops specifically for that application. I forget the name, but they were expensive IMO.
Old 06-20-2008, 12:42 PM
saftman's Avatar
saftman
saftman is offline
Try Helwig.com
Old 06-20-2008, 02:01 PM
saftman's Avatar
saftman
saftman is offline
Also Timbren.com
Old 06-20-2008, 07:38 PM
spinella's Avatar
spinella
spinella is offline
i second the timberens.they work great.
chappys4life
16
04-20-2012 01:28 PM
Dlinzy
07-03-2007 12:52 PM
84f250460
03-20-2007 11:17 AM
C. Lee Colbert
03-30-2006 08:20 AM
csallen
1983 - 2012 Ranger & B-Series
08-08-2004 12:12 AM
Quick Reply: helper springs
