Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2008, 10:53 PM
StevensPoint is starting off with a positive reputation.
Electrical Connectors - What kind does Ford Use?
Can anyone tell me what type of electrical connectors Ford uses? Specifically on the fuel pump for the 6.0? They don't look like weather-pack or metri-pack. Similar to Molex, but not quite.
Thanks for the help.
__________________
2006 King Ranch
29,000 miles
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-19-2008, 04:51 PM
william_04_x's Avatar
william_04_x is starting off with a positive reputation.
whatca buildin'?...
IIRC most people call them molex and i don't know if that's correct either...if you need one for a project, you might get friendly with a local tech and he can cut a pigtail off for you..
when i put my fuel system in, i'll do the above and have a seperate connector for coil voltage to the new pump's relay...i'll leave the factory HFCM in place as a back up..if there's a problem, i can unplug one and go to the other..
__________________
William
Southern Nevada Power Strokes.Org
04 Eddie Bauer Excursion w/03 6.0l PSD/ARP's
4" MBRP T-409 SS exhaust/straight piped
4 gauge A-pillar w/DiPricol Optix boost, pyro,
fuel pressure, and trans temp
SEIC Mod
Infinity door speakers and Alpine amps and subs
Ride Rite air bags and Hellwig rear bar
Train Horns
27' 05 WW FS2600 Toy Hauler
  #3 (permalink)
Old 06-19-2008, 05:27 PM
Quote:
That's my plan. I'm running a Fass HPFP. My plan is to take power from the stock pump harness, run it to a 5 pole relay that is controlled by one of the Upfitter switches. Flip the switch and it shuts off the stock pump and powers up the Fass pump. I'd like to do it all with factory harnesses.
Thanks!
__________________
2006 King Ranch
29,000 miles
  #4 (permalink)
Old 06-19-2008, 07:40 PM
Quote:
Thanks!
I had a feeling it was something like that....
post your progress..you get a fully auto system (switching fuel inlets and outlets between pumps) and i may follow right in your footsteps...good luck..
__________________
William
SEIC Mod
Train Horns
  #5 (permalink)
Old 06-19-2008, 10:32 PM
My system will be fully auto, except that it will have two completely separate fuel systems, tank, filter, pump, fuel lines. The new fuel lines will come in the back of the head. If you wanted to use the stock fuel system and run two pumps you would have to break into the aluminum fuel lines and tee off to the new pump. You would also have to install some check valves in the system to prevent pressurized fuel from going back to the tank.
__________________
2006 King Ranch
29,000 miles
  #6 (permalink)
Old 06-19-2008, 11:25 PM
that sounds really good...
i plan on a simple 3 way valve set up with a larger tank pickup and lines feeding both pumps...a 3 way before the pumps will keep them from backfeeding to the tank even if i tee them back together after the pumps..then a regulated return up top to control pressure..i have a 44 gal tank already so i really don't need to carry more fuel...the stock HFCM will only be a back up and hopefully rarely used..
if i add a relay for the pumps and a 3 way valve w/solenoid i can make it auto also....hmmmmmmmmm
what's the purpose for your system?...i simply need a larger volume of fuel than stock can handle...as it is, i have times when i'm at 40psi and that's a little low for my liking...
__________________
William
SEIC Mod
Train Horns
  #7 (permalink)
Old 06-19-2008, 11:27 PM
__________________
2006 King Ranch
29,000 miles
  #8 (permalink)
Old 06-19-2008, 11:36 PM
My second tank will contain vegetable oil. Two completely separate systems that will both be used on a daily basis. I'll have pics available in a couple weeks when I'm done.
__________________
2006 King Ranch
29,000 miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
