Keyless Entry Code
2010 expedition 5 digit keyless entry code
2010 expedition 5 digit keyless entry code location. It is located on the (SJB) smart junction box, Passanger side fuse box, remove the plastic panals and look on the rear of the fuse box you will see a sticker with the code. No tools Required!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I just removed the passenger plastic rocker panel, then part of the weather stripping, then pull on the passenger side kick panel it will come right off, you will see the SJB and the sticker, I took my pocket knife to start prying the sticker off once started just pull it off there is plenty of room, this project will probably take you all of 15 minutes.
Tremendous tip!!! Thanks a million...
I just bought an 08 Expedition as primary vehicle for my wife to drive.
Did not think to check when I bought it, but the keyless entry card was missing and nothing written in the manual.
I tried to call ford to get the code with my vin number and they waned me to go to dealer who wanted to charge me 60 bucks to get the code out of the computer.
I was going to take it to the dealer, but before I got a chance by wife locked the keys in the car. To make matters worse, my son was strapped in the car seat.
The next day, my brother in law found this for me.
Worked like a charm.
I just had to sign up and post a big "Thank you" here!
We bought a 2007 Expedition EL Limited a little over a year ago and it had no "glove box goodies". No manuals, no key code card, and only 2 keys (no fobs).
I've been searching through a lot of wires under the dash with no luck. However, I ran across Viperinu2's post with pics and found our code! The location of the SJB is the same as pictured on ours, however the label was different and the 5-digit code was pretty well smack in the middle with barcodes above and below it.
