Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2008, 09:22 PM
66f-100 is starting off with a positive reputation.
two '66 questions
OK, first question is where is my spare tire supposed to mount on my '66 F-100 styleside. I don't see any mounts in the bed area. Does it mount underneath?
Second question: I just replaced the headlight switch and wanted to make sure I had it in there correctly. Does the headlight release button on the switch point towards the driver's side? I didn't pay attention to the orientation when I removed it.
Thanks,
Mark
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-18-2008, 10:42 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
the spare mounts under the rear of bed
there should be an index tang on the switch to alighn with slot in dash hole
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #3 (permalink)
Old 06-19-2008, 06:22 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
Second question: I just replaced the headlight switch and wanted to make sure I had it in there correctly. Does the headlight release button on the switch point towards the driver's side? I didn't pay attention to the orientation when I removed it.Thanks,Mark
There's a T shaped crossbar held to the frame by two long bolts. The spare rides above the bar, the T portion fits thru the center of the wheel. The jack and lug wrench fit inside the spare wheels rim.
The headlamp switch knob and shaft release button points straight up.
See the dash illustration and all the switches, knobs, radio, heater etc. here: Body Section 030 / Page 8.
See the entire exploded view of the spare tire carrier here: Chassis Section 14 / Page 5.
These illustrations are from the 1964/72 Ford Truck Parts Catalog.
A CD version of this parts catalog is available from hipoparts.com (also sold on ebay), for around $22.00.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #4 (permalink)
Old 06-20-2008, 02:29 PM
customcab66's Avatar
customcab66 is starting off with a positive reputation.
I know that on my 66 the tire hanger was still under the back edge of the bed, I even have an orignial spare wheel and tire to go in the truck when I get her finished.
__________________
Allen D. Jr
1966 Custom cab truck
1967 Fairlane Ranchero
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
