Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2008, 07:04 PM
ace555's Avatar
ace555 is starting off with a positive reputation.
Cleaning The Engine
Hey I was just wondering how you guys keep your engine clean? as my L's engine is starting to get pretty dusty this time of year - is there anything I need to watch out for before I do and what products are the best to use on it?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-18-2008, 07:49 PM
Stewart_H's Avatar
I Have A Need 4 Speed
Stewart_H has a good reputation on FTE.Stewart_H has a good reputation on FTE.
A pressure washer on its highest setting is the only way to go, and the only proper way to clean the engine bay.
Ok, ok...so I'm a kidder!
Don't use a pressure washer. Heck, you really shouldn't even use a garden hose, just a wet rag, but I've been known to be a "bad boy" and wash my engine bay from time to time with a small stream of water from my garden hose. But I'm reeeeeeeeeeeeeeeeeeel careful not to get it anywhere near the COP's, the alternator, or any part of the wiring harness where it connects to something. As you can see, that doesn't leave a lot of area's to really safely use a hose, hence the "don't pressure wash or use a garden hose" warning!
I like using CD-2 engine cleaner/degreaser and detailer, but they don't make it anymore. All they have now is the CD-2 detailer.
Some guys use Simple Green.
Using a wet rag and thoroughly wiping/washing the engine down, then using a good spray detailer like CD-2 Engine Detailer will do wonders for ya.
Stewart
__________________
1999 F150 Lightning
- Woodbine Motorsports built block
2000 PSD 4X4 Excursion
- John Wood tranny, DP-Tuner, AFE, MBRP 4", BDP 1.0, Overboost Annihilator, ITP Pre-Pump mod, Gauges from ITP, V & B code springs, Hellwig rear sway.
  #3 (permalink)
Old 06-19-2008, 07:38 AM
TexasGuy001's Avatar
TexasGuy001 is starting off with a positive reputation.
DO NOT use a pressure washer. As mentioned before, bad idea.
If you have an open element air filter cover it up with an HEB bag.
I use simple green and a garden hose. I have use Gunk engine degreaser a few times over the years if its really dirty. You would be fine with simple green and the hose. I haven't seen what yours looks like it might clean up nice with just a light rinse. It works good is you have an adjustable hose "gun" attachment that will allow you to fan the spray then its not high pressure at all. Whatever you do, don't go to the car wash and do it unless your engine is given plenty of time to cool down. If you do this I wouldn't use the degreaser there it can hurt the paint on your fenders and bumper etc. Its not likely but I have seen it happen. You can go this route and just use the higher pressure rinse and hold the gun away from the engine not letting it get too close.
That CD2 detailer makes the engine bay look very nice, but everything is greasy or oily and hard to work on. I used it once, needless to say that I used simple green and rinsed it all off. Thats about all I have to say.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
  #4 (permalink)
Old 07-17-2008, 04:18 AM
khadma's Avatar
<I really look like this
khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.
Simple green at oil change time, the engine on a street driven truck is usually not too dirty in the 3000-5000 mile interval ranges.
__________________
1996 Bronco xlt 5.8,a/t,a/c,31x10.5 BFG's A/T
1999 Ranger supercab xlt 3.0, a/t
1984 Bronco 4.9l, 4spd manual
2002 F150 regular cab shortbox XL 4.2 a/t
1995 Windstar
2007 Explorer XLT 4.0 a/t
1988 Mazda B2200
Member of the Hawai'i Carpenters Union - Local 745
Darren
  #5 (permalink)
Old 07-17-2008, 06:44 PM
1957F100 is starting off with a positive reputation.
haha when i was 14 i worked weekends at a local car detailing shop. First thing we did before bringing the vehicle into the shop to clean the interior was wash the car outside. and while i was washing the exterior of the car the owner of the company would be cleaning the engine with a pressure washer...that was always on full blast. we never had a problem though...that i was aware of.
__________________
1957 Ford F100 - 302 w/ C4. Work in Progress...
1993 Ford F250 4x4 - 7.3L Diesel, ZF 5 Speed
Mods - Soup Bowl Removed. Hypermax Cowl Air System Installed. Autometer Ultra Lite Gauges. South Bend Clutch.
  #6 (permalink)
Old 07-17-2008, 10:23 PM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
You can't use engine cleaning techniques for other engines (pressure washer, etc.) on modern Ford engines. The COPs can be very sensitive to water. Water directly on the COPs can cause them to fail and water in the spark plug holes can evaporate into the COPs either immediately or at a later date causing them to fail.
__________________
-Ken
Look, I'm gonna have to ask you to go ahead, just come back another time. I got a meeting with the Bob's in a couple minutes.
See "IB Tim" for support.
2006 Roush F150 Project: Roushcharger, Troyer Tuning, 9lb pulley, E-Fans, Headers, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Head/Tail Lights, Retrax Tonneau, more...
04 F250 King Ranch Crewcab 6L PSD project: DP-Tuner Tuning, MBRP Stainless Dual Exhaust.
00 Ranger Supercab XLT 3.0 V6: Bright Box, Mac Intake, Borla exhaust, my tuning.
RIP: 67 & 75 F100
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
