Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2008, 01:00 PM
jklapp86 is starting off with a positive reputation.
High idle 351w
I have a 94' f150 with a 351w and intermittently it will have a high idle (1000-2000rpm's) it will do it at start up and after cruising, could a vacuum leak cause this? any info would be nice, thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-20-2008, 07:46 AM
idle problem
Could the intake runner gaskets be leaking causing unmetered air to enter intake?
  #3 (permalink)
Old 06-20-2008, 09:20 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Yes, that's possible. Has it shown the check engie light anytime recently? It's a good idea to pull the codes anyway, Ford Fuel Injection has a simple DIY proceedure for this. A sticking IAC or faulty TPS could also cause this.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #4 (permalink)
Old 06-20-2008, 09:58 AM
i had it at our shop yesterday and i pulled codes, no codes and we got it to idle high in the shop, unpluged the IAC and it idle down to proper level. So we came to the conclusion it was being commanded that way ruling that out, we did find that the canister vent solenoid seemed like it was sticking, i would have vac. at elevated idle so we unplugged it an still there was vac, according to the ford WSM that solenoid it only suppose to purge when grounded. could that cause elevated idle from being in a constant purge state?
  #5 (permalink)
Old 06-20-2008, 12:55 PM
IcemanV8 is starting off with a positive reputation.
If you unplug the TPS, does the idle come back down to normal? Try that with the IAC plugged in.
Sounds just like what my 302 was doing with a bad TPS. Only difference.... mine showed up when I pulled the codes. That's what leads me away from it being electronical, unless it was a user mistake pulling codes, or it didn't have time to show up in the codes, yet.
How "I" check the code reader is by having the engine running, unplugging the EGR, let it run a few seconds, plug it back in. It should show up on the code reader. If not, something isn't working, or you may even have a bad computer.
__________________
1986 Ford F-150 4x4 5.0 EFI
XLT Lariat
NP435/NP208/9" 3.50 axle
Road Warrior bumper, Leaf Spring Overloads
  #6 (permalink)
Old 06-20-2008, 01:05 PM
Conanski's Avatar
Yeah.. if you unplug the IAC and it idles down I'd suspect the TPS, it may have a dead spot and be giving the computer bad info. An analog multimeter will show this as you sweep the throttle through it's range, http://www.fordfuelinjection.com/?p=30
__________________
Paul O
  #7 (permalink)
Old 06-23-2008, 10:06 AM
When i pulled codes on the vehicle i did it with the old ford NGS system tester. Had our senior master tech aid me in trying to diag. the cause so it wasnt a human error plus it showed up codes from us unpluging the egr and such when we were messing around. Sound like a TPS but without the codes.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
