Power Steering Pump reservoir cap??? - Ford Truck Enthusiasts Forums
Old 06-18-2008, 12:11 PM
atomicjoe23 atomicjoe23 is offline
atomicjoe23 is starting off with a positive reputation.
Our truck ('79 F-150 4x4 351M/Auto) doesn't have a cap on the power steering pump reservoir (we have the plastic reservoir not the metal one) and we can't find/figure out where to get a cap for the reservoir. . .I've seen the dipsticks for the power steering pumps but I don't see where it goes on our steering pump. In all of the online pictures of the power steering pump that I have seen (Autozone, Schucks, etc.) there isn't a cap on it either. What kind of cap is the reservoir supposed to have and where can we get one. . .we've already been junkyard scavenging for one. The only one that I've seen come with a cap is the Extra Duty version but it's way more expensive (twice as much) and we just don't feel like buying a whole new Extra Duty power steering pump when all we need is a cap for the reservoir.
Same question for a dipstick for the engine oil. . .ours came without one and I can't find one for the 351M anywhere. . .I got one from the junkyard but it didn't fit (I didn't check to see if the truck I got it from was 4WD or not so I'm guess that the odds worked against me and it was 2WD so it won't fit our 4WD oil pan!!!
Thanks FTE!!!
Old 06-18-2008, 08:19 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is online now
78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all
i think ford rangers and explorers have the same pump, it is a common pump. 351m, 400 same dipstick.
Old 06-20-2008, 05:04 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1978/79 F100/350 & Bronco P/S Dipstick
YF1Z3A006AA .. P/S Dipstick ~ Use with the FORD type P/S pump / Replaced: E6DZ-3A006-A, E1AZ-3A006-A/B, & the original 1978/79 p/n of D8AZ-3A006-A.
MSRP: $5.90 / ftepartsguy.com price: $4.25
Note: 1977 and earlier cars/trucks used a different pump, the parts will not interchange.
This dipstick is not the same one 1975 and later Econolines with Saginaw P/S pumps used.
Old 06-20-2008, 05:08 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Your didstick/cap looks like this look at this one
As common as can be used in all plastic tank saginaw pumps. You can find them from 79-97.
Old 06-20-2008, 06:26 PM
2tone73 2tone73 is offline
2tone73 is starting off with a positive reputation.
I got one you can have.
power steering/ hydroboost juanbad79 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-10-2016 05:47 PM
1999 7.3L van power steering question boxcarwilly 1968-2013 Full Size Vans 2 12-01-2015 07:13 PM
turbulence in the power steering reservoir dbuck50 2004 - 2008 F150 1 07-29-2015 07:58 PM
Power steering reservoir swap hivoltj 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-03-2015 09:58 AM
Power Steering Leak steveamann 1987 - 1996 F150 & Larger F-Series Trucks 4 11-10-2014 09:35 AM
Tags
2000, 2001, 2011, cap, f150, power, reservoir, resevoir, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
