Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2008, 08:06 AM
78bigunns's Avatar
78bigunns is starting off with a positive reputation.
Dt466 from a older IH cabover
Probably end up getting the truck for free or close to it.
Runs and drives, low mileage as it was a military used rig.
Has a auto tranny in it.
Thinking about a swap project.
Any idea of what kind of hp and torque output it has?
I'm thinking it's early to mid 80's vintage, I think the truck is a Loadstar or Paystar. Can't remember.
2 axle semi tractor cabover.
I need to get a year and model, but it's at the side job, so it will have to wait.
Thanks for any input.
__________________
-- Blair --
96' F350 CrewCab 4x4, 351
79' F150 Custom 460 np435 np205 4x4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-18-2008, 10:30 AM
Lead Head is gaining momentum as a positive member of FTE.Lead Head is gaining momentum as a positive member of FTE.
I'd guess between 220-250HP and ~660 ft-lbs of torque. The DT466s, can make quite a bit of power with the right mods.
You are definitely going to run into issues fitting it into a F-series though.,
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #3 (permalink)
Old 06-18-2008, 10:57 AM
78bigunns's Avatar
Decent numbers for sure IMHO.
I've been toying with the ideas of a Cummins 5.9 swap, but have the DT literally in my hands.
I have looked around with the Google and found several guys have done the swap for pullin' rigs and the like.
Couple guys are using them for regular drivers too.
I have read about the front to back issues, radiator issues, and using a intercooler.
Would have to do some firewall work for sure with a Cummins, new mounts, new crossmember, diff radiator too, so thinking out loud how much worse could it be to work on the DT swap?
What mods can be done for cheap to the DT?
And I'd have to figure out a tranny option.........
__________________
-- Blair --
  #4 (permalink)
Old 06-18-2008, 12:40 PM
origcharger is gaining momentum as a positive member of FTE.
DT 466 power ratings, especially in the 1980s, could be as low as 175HP and about 450 ft lbs. torque. If its a military speced vehicle I would not count on it being a high horsepower version.
The DT466s we have range from 175 h.p to 220 h.p. and none are over 540 ft. lbs. torque. Higher torque ratings are available but require an expensive transmission upgrade.
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #5 (permalink)
Old 06-18-2008, 12:45 PM
78bigunns's Avatar
More interesting info.
Thanks for posting. That is a big worry of mine, I don't want to chase the swap when I could have bought a 12v and been done.....!
I'll keep reading, thanks for the reply.
__________________
-- Blair --
  #6 (permalink)
Old 06-18-2008, 01:05 PM
I just found the specs, and the DT466 is about 5" longer then the 5.9, and weighs about 500 lbs more.
If you can come up with a plan to get the DT466 to fit in there, I would take it over the 5.9, but you will have to factor in the even greater weight it is over the 5.9
EDIT: Looks like I was a bit off on the power ratings, the new DT466, called the Maxxforce DT puts out around 300HP, and most things I've seen placed the DT466 at around 230HP, the old one that is.
Anyways, I would look around to see what your power requirements are, and how much it would cost to meet your needs.
I have heard some bad things about the Allison auto transmissions though. They will last forever at their rated power level, but start to go a little bit over, and it will be blown in no time. The same thing even seems to apply with the ones behind the Duramax.
__________________
- Ian
  #7 (permalink)
Old 06-18-2008, 01:26 PM
78bigunns's Avatar
Thanks for the info Ian.
Not totally sold one way or the other, but here is what I'm thinking...
DT in hands, little to no cost. The truck is from a bunch of rigs my buddy bought, we have hauled all the 6.2's and the other military blazers and pickups circa 1985.
I've been hauling for him with my pickup and trailer, and there is scrap to cash in on.
All that is left is the IH with the DT466 and one trailer.
Supposedly runs, really good miles on it.
Was driven to where it sits.....year ago maybe.
So, I may have to buy him out with my coin from the scrap, but we're not talking alot. Even so, I may get it for free. We've talked about it.
Would need mounts either 5.9 or the DT. I'll fab them probably. I have a bunch of 5/16" steel here in a bin....
Need rad and intercooler either way.
Need crossmember or fab one either way.
Who knows about the auto tranny in the truck. If it moves the big truck, and looks like it could be used, maybe we'll try.
Otherwise I may try and have an adaptor made from the DT to a handshaker. Or build the dickens out of a auto and run it with coolers and the like. It's only money right?
4wd is going to be kept, I'm thinking a divorced NP205. Have a couple of those.
It's going in a F350, so maybe some heavier springs up front and all that weight can be held and the ride wouldn't be too harsh.
I've read about doing a body lift to accomdate the big motor, I think it could be done,gonna have to track down someone who has one in their pulling truck and get some time with them.
Anyway, my wheels are turning for sure.
__________________
-- Blair --
  #8 (permalink)
Old 06-18-2008, 10:22 PM
nevrenufhp is starting off with a positive reputation.
To keep your wheels turnin;
what you're likely to see is a DT with a rotary injector pump, and 210 or less hp. That means a couple things: 1, you'd need to swap to a later style Bosch pump(not too expensive). 2, the turbo isn't the best for any performance.
A handshaker trans would be much more reliable than an Allison. You can get an Alli to hold big power, but obviously takes big bux.
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
Project: 99 Stupor Duty F250, 2WD, AT545, waiting for DT466(IH power)
  #9 (permalink)
Old 06-19-2008, 06:32 PM
78bigunns's Avatar
Thanks for the input guys.
I'm still not sold, but leaning hard. Of course I came across a 5.9 Cummins today, for under a $1000, runs tight and seemed all in order. Was a 92', turbo'd.
I really think a Cummins would be the easiest, I have a guy who wil lrebuild my E4OD for stupid cheap (He is our company mechanic and owns a trans shop), he guaranteed it to hold for high torque.
And having an adaptor for several hundred and essentially bolting it up is very appealing.
Of course if the stars aligned and a tranny fell into my lap for the IH motor, then that could motivate me more in that direction.
Lots to decide, I like different swaps, but the truth of the matter is this is my towrig/toy, so I don't need a killer motor.
I just want to get power and mileage and the 5.9 would get me there easiest I figure.
More research to be done on the 466.
Thanks guys.
__________________
-- Blair --
  #10 (permalink)
Old 06-19-2008, 09:37 PM
The only problem with the 92 cummins is they have the rotary VE injection pump, not the best for making power like the 94-97.5 P7100 inline pump
__________________
- Ian
  #11 (permalink)
Old 06-20-2008, 07:49 AM
78bigunns's Avatar
Right on.
Can the pumps be swapped?
Upgraded maybe?
__________________
-- Blair --
  #12 (permalink)
Old 06-20-2008, 12:34 PM
Looks like the P7100 pump swap is fairly involved, different injectors, injector lines, timing cover and bunch of other stuff.
Looks like you can turn the VE pump up somewhat, get an intercooler for it, and I guess you should be able to get somewhere around the 300-350 RWHP range.
__________________
- Ian
  #13 (permalink)
Old 06-20-2008, 12:59 PM
78bigunns's Avatar
Thanks, been researching the Cummins swap to try and get as much info on everything I can.
__________________
-- Blair --
  #14 (permalink)
Old 06-20-2008, 01:49 PM
deereman4020's Avatar
deereman4020 has a good reputation on FTE.deereman4020 has a good reputation on FTE.
FYI you should go to either www.fordcummins.com or www.destroked.com
good luck with the swap.
__________________
2002 Ford F-250 7.3 psd crew cab long box
6637 waiting to go in.
PAA Member #63
Support the troops
Jacob
  #15 (permalink)
Old 06-20-2008, 01:58 PM
78bigunns's Avatar
Thanks Jacob, I'm on a couple forums for swaps, I was leaning heavy on the Cummins and started asking questions last year and got laid off so it went on hold.
Of course diesel is through the roof for now, until the bubble bursts, but I plan on doing a alt fuel with the truck when it's done regardless.
A good site is Cummins-conversions.com too. Been looking hard at the Destroked adapters if I go Cummins. Rebuild my tranny and get going........
__________________
-- Blair --
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
